AR-DV10 My AR-DV10 Connect app
depmicro
France, Avignon
Good morning,
I think I included all the functions I needed on this DV1/DV10 app.
Development will therefore be stopped with this version (v0.991d).
If you have any suggestions for features or improvements, now is the time!
Thank you all.
bonfi6000
V0.975d
Tetra GSSI user group filtering
TETRA GSSI filter added, but under testing.
GSSI Key is not useful or requested
I am waiting for your feedback on this function.
Especially for DV1 users.
Thank you all.
Tetra GSSI filter would be a great added feature. Would really appreciate to see it included in future versions. Thanks Great Work!
depmicro
France, Avignon
The Tetra filter only works for the DV10.
See the “Tetra Information” Tab in my software.
It would be possible to make it compatible with the DV1, but unfortunately I do not have the DV1 to work on this function.
Do you have a DV10 or DV1?
mmora76
Beinasco (TO) - Italy
Good morning
I am an owner of an AOR AR-DV1. I'm trying your software which I consider very valid and promising. However, I noticed some problems:
1) The value of the received signal is not read.
2) In Tetra TM mode the network information cannot be read
3) The GSSI Filter function does not work.
4) There is no possibility to turn on the receiver remotely.
As I told you, I am a DV1 owner with GSSI Tetra Key enabled. If necessary, I make myself available to test the functions that are still not working.
Thanks anyway for the work done so far and I hope you can continue to develop the functions that are not yet fully functional.
depmicro
France, Avignon
Good morning,
Thanks for the feedback.
Unfortunately the "Tetra information" function is not compatible with the DV1.
The function to turn on the receiver remotely is not included in the DV10, therefore, it is missing in my software.
If one day I am lucky enough to own a DV1, I might eventually include its specific functions.
Software development is currently at a standstill.
Thank you all.
Bonjour,
Merci pour le retour.
Malheureusement la fonction "Tetra information" n'est pas compatible avec le DV1.
La fonction pour allumer le récepteur à distance n'est pas incluse dans le DV10, donc, elle est absente dans mon logiciel.
Si un jour j'ai la chance de posséder un DV1, je pourrait éventuellement inclure ses fonctions spécifiques.
Le développement du logiciel est pour l'instant à l'arrêt.
Merci a tous.
wb4sqi
Amelia, OH
Ran your software this morning and it worked very well. I can understand it is heavily weighted for Euro operations mainly due to Tetra/GSSI so adding North America to your community isn't logical. Otherwise, the memory functions work well for me. Nice work.
SM5WPW
Just installed it to my 2 DV-1´s, but under Community folder you need to select country but Sweden is missing.
Would you like to translate the software into swedish? /Mike
depmicro
France, Avignon
Hi SM5WPW,
The community function is going to be removed from the software, because I think it is not really useful.
For the translation of the software, I use an automatic translator, if you think it is useful, I can add Swedish.
depmicro
France, Avignon
Mise à jour V1.0.0.37:
Import/Export de fichier Excel (xlsx) ou csv
Enregistrement des mémoires de l'appareil à partir de fichier CSV ou XLSX
BigEarsNL
Netherlands
Hello,
Nice software, works great on my DV1 GSSI filter is not working, no problem, but where is the recorded audiofile stored if i hit the record button i am trying to find it on my win10 pro version 64 bit.
Hope you can help me, grtz from John in the netherlands
depmicro
France, Avignon
Hello,
Bonjour,
Ce logiciel sert de télécommande pour le DV1 et DV10, vos fichiers audio sont donc enregistrés dans la carte SD de votre appareil.
W4KRR
Coconut Creek
So, this program won't work unless the radio is connected to the PC? I was wanting to build a codeplug before the radio arrives.
depmicro
France, Avignon
Oui, il faut un DV1 ou DV10 connecté au PC pour que le logiciel fonctionne.
En pièce jointe un fichier excel de ma sauvegarde pour créer un codeplug.
  • AR-DV10_Connect-Save_28112024_182614.zip
W4KRR
Coconut Creek
Merci
Je vais l'utiliser pour construire un codeplug jusqu'à ce que ma radio arrive.
Thank you
I will use this to build a codeplug until my radio arrives.
