need to ask a question to all
raymondjtoth
des plaines il
See I'm learning this keeps my mind off surgery for ears when not doing online college homework. Next month surgery scanner radio at least keeping my mine off it since, scared allready
wtp
Port Charlotte FL
145.8 and 145.825 when around you. (not a lot of activity)
and to put some of them in order...
need to lookup a number,
RBMTS
Sorry to say - no. Unfortunately your scanner is very limited in what it can hear. Most of the PD's are on the state communication system which your scanner won't pick up. You'd need a much more advanced digital trunking scanner like the Uniden SDS100 or SDS200. Some cities (such as Mount Prospect, Elk Grove, Buffalo Grove, Cook County Sheriff) are encrypted which means that no scanner can receive them. The links that I and others have provided you will show some of the regular things you'd be able to hear. At best, you can listen to the Des Plaines Fire Department. That's more than some people have.
Make sure to program in the Chicago PD frequencies, especially the city wide channels. There is never a dull moment listening to them.
raymondjtoth
des plaines il
no not pd i mean like rail road and taxie other than pd that i can pick up i meant non encrypted stuff not pd other stuff like school busses and so on if helps rmbts
RBMTS
All of the available local services are located in the links that connect to the database for cook and DuPage counties. Railroad, schools, transportation, etc. Give some a try and see if you like listening to them.
raymondjtoth
des plaines il
thanks all for helping me, out and , understanding what i can aford wanted ghood starter radio them move up once ready to dew to my autisum this is way i think i should go. thanks for helping agen. if think of any more use full stull for me please let me know thanks.
Scan125
UK
Finding out / probing what is active in your area is part of the scanning hobby.
The (U)BC75XLT has both custom search and services scan function. You can manually use these and save interesting hits back to your own Scan Channels/Memory locations.
If you want to more automate this search / save / log / audio record the transmissions in your area then you may want to checkout/try Scan75. Scan75 is free but officially a voluntary charity ware application. Charity donation is not compulsory and no program functions are limited but if it "floats your boat" then the DEBRA charity would be grateful of any donation from $1 to your personal appreciation value.
Scan75 can be found at: Scan75 Control Program
jaspence
Michigan
Maybe I read through the replies too quickly, but isn't he close to O'Hare International Airport? Should be able to monitor most of their air frequencies. When I visit my family in Vernon Hills, I also listen to the Metra and rail frequencies.
