New President Randy FCC handheld/mobile CB
bearcatrp
Land of 10,000 taxes
If we could get allot of folks to email the manufacturer asking when is a SSB Randy coming out, could prod them into action. I caked them about SSB shortly after I bound mine and was told no plans are on the table. Email them once a month!
slowmover
Fort Worth
More
Finally (it looks like) an excellent handheld antenna is available.
slowmover
Fort Worth
More
Who’s gonna be first?
slowmover
Fort Worth
Dug my R-2 out of the couch cushions and took it with me on a day of errand-running. Need to figure out how best to use it as a backup.
BATT Pack attached and plugged into cigar lighter. (Adds no noise). PRESIDENT Texas on roof.
1). Distinctly needs RF/CMC choke at radio end of coax. Found my P-E version of that today.
2). Need an adaptor to run the WEST MOUNTAIN RADIO CLEARSPEECH Speaker. This radio isn’t pleasant to which to listen all day (similar to a UNIDEN 880/885/980). Lacking NRC is become a handicap since 2023.
Left that at home, but believe I have a step-down jack adapter somewhere. Past experience is that the Unidens and a Randy are tamed by DSP.
3). So, am having to use ASC to avoid turning SQ half-closed. Compander and Hi-Cut are on. ANL/NB, off.
I’m in a major metro where the amount of hash & trash is high.
ASC is a nice feature for some uses, but it wipes out faint signals and degrades the closer ones.
You and your friends are caravanning and want an R-2 on an adjacent FM channel, then ASC seems ideal.
For GP automobile use you need an external speaker. Or headset. (Get both). Lapel mic/Speaker is also handy.
Found a RigRunner, too, so W-M speaker & KL-203 to jack it up next trip.
There’s plenty on AM-19 where I am.
But can’t hear or be heard with present config.
slowmover
Fort Worth
Compander function (and Hi Cut) are ON as givens, from here.
Being able to avoid ASC looks like the trick for AM-19 use (busy channel + distant warning).
DSP Audio devices can be found new or used.
Looks like my retired W-M integrated speaker and a spare KL-203 + R-runner earned a spot with Randy as pickup truck back-up radio . . . not just as a mobile extension to the main rig (think I’ll toss in the U980 also to free up Randy; otherwise can patch it in).
— I need to build a harness extension to avail myself of 12VDC run for the main rig, and maybe a board mount to Velcro to center console.
2800 & 3800 Apache transport cases to divide up gear for removal, and to carry dedicated supply + tools in general.
Given, (master proposition) this:
Post in thread 'Looking for advice for a new CB radio "system" for my pickup truck'
then being able to remove all the 11M stuff to safe transport/storage gives a framework to pickup mobile ops.
Antenna storage a separate subject.
slowmover
Fort Worth
Example of $7.00 3.5mm female to 2.5mm male adapter to run a speaker from the radio side socket.
These “digital radios” as we were calling them after circa 2012 intro of Uniden 880/980 have a high level of “hash” in RX audio which is wearying in all-day use.
DSP devices in Audio are a fix, but expensive.
The difference in sound quality just from smallest speaker (lapel mic/speaker) to built-in radio speaker is noticeable.
With Randy we are unable to back off the RF Gain (needs maximum with portable antenna dimension limits) as one would do with U880/980.
So I’ll suggest a Cobra 300 mobile extension speaker as a low-cost bit of help. Better audio fidelity with that larger cone to better spread the freq.
A dedicated speaker to customize (sound enclosure, internal noise reducers, etc) to get the most from using Randy or Jerry as walkabout plus backup to the main mobile rig.
Obviously, a D-E DRX-901 is an ideal choice where it’s the main radio rig extension speaker
I gave these to fellow drivers for a few years as gifts in recognition of training & help received. Still have a couple. Find at PETRO/TA or online (Bells CB).
