New PSR-800 questions
White Bear, Mn.
Cool scanner! Most everything I listen to is on the "ARMER" system in Minnesota. When using the EZ Scan software doing a "library import", I would like to know if it makes any difference what sites I choose (if any) before I choose the departments under talkgroups after selecting the ARMER system. The Ramsey county simulcast site is the close one.
Question 2: For the life of me, I cannot find the battery voltage level settings under the advanced tab which was posted by "BeerNutz" a day ago?,
Thanks in advance, Great site BTW............Jim
GrumpyAeroGuy
Cincinnati, Ohio
you may have better luck posting your Minnesota specific question in the Minnesota forum. Might get a answer quicker... (?)
N0WEF
Mpls, MN.
For Q2, you need to go to the top of the window and click "Advanced" under the drop down menu you will see "Show Advanced Tab" click that and the tab at the bottom will show up.
Click that tab and you will see the "Voltage" box.
