NexEdge remote control
fuze
Poland
(sorry for my English)
I wonder if there is any possibility to remotely control NX radios?
ex. I'm talking about configuration like this: PC <-cable-> NX700 <-air-> NX200 ( or PC <-cable-> NXR700 <-air-> NX200). I know that it is possible to start PTT in configuration PC <-cable-> NX700 / NXR700 / NX200 (using command: Speech Call Start etc.). In my configuration I have one transceiver (NX700) connected to PC and I would like to control all my other radios (NX200) through 'air'. I hope you understand what I'm trying to say.
I have one more question. I wonder if anyone knows which protocol is used for audio streams between NXR. I read in NXDN documentations that NXR can communicate using IP, so they have to transmit audio stream as well. My question is if they use RTP ( or SRTP ) for audio streams?
code3cowboy
CA-CZU
Local Control is possible with the nx series base stations. You use the D sub connector on the back of the radio.
Costa Rica
hello friend, I need help with my nx 700. I'm from Costa Rica, the Commission decided to move to digital technology icom comings, we're testing with a 700-hk nx digital mode the which works perfect
testing a software called virtual console radio, the problem is the Interfas to connect to the PC, you could help me with some plot to create this to download gps data?
hablo español
Neopacolipse
Vernon/ Barton County MIssouri
Software/ connector
How would one connect to use the dsub port in the back for local computer control of a radio. Is there a software that should be used for this?
I am looking to set up a NX-700 to be controlled from a Windows 7 computer. The computer has serial and usb connections.
All help would be appreciated.
domes
I'm not sure I understand the above questions? All you need to connect a PC to a Kenwood NX-x00 radio is a "USB to Serial DB25 adapter cable" - Off the shelf computer item available on internet for under $20. You will have to program the radio to send data to/from DB25 on back of radio. You need some kind of software in your PC. Kenwood's KAS-10 Dispatching & Mapping software is available for under $500 list. You can set up the Dispatching programs to make a simple remote or a complex console to control multiple radios, groups & ID's. Send & receive text and call logging.
The Mapping portion allows you to select up to 20 radios on the screen at a time. You have to furnish the map of your choice. I like to use MS Mappoint but I believe the current price is about $400. You can download Google Maps for free but takes some time to figure out the process.
If you have an internet connection at the repeater/trunk site, you can use KAS-10 to set up your PC as a "Virtual Radio" without an RF radio. For a Virtual Radio you also need a USB vocoder thumb drive. You can use the PC's built in speakers & microphone & program an "F-key", space bar and/or on-screen mouse click for PTT. The built-in mic sounds good but my experience is that the built-in speakers aren't loud enough and sound muffled. A good set of amplified external speakers designed for your model PC will greatly enhance audio quality.
bart
