NX-1200AVK2 programming issues
tp636radio
Anybody else have the new NX-1200AVK2 radio (the analog version)? I just purchased a bunch of them along with the KPG-D6N program software since the TK-2312s are being phased out. My issue is whenever I go to read or write to the radio, I get an error message "Ensure that model name and market code are correctly entered". If you go to "Model - Product Information", the only models that show up in the list there are the 1200NV/DV and the 1300NU/DU, no AV models are listed. However, if you go to "Tools - Transceiver Information" it reads the radio & displays the correct Model Name & Market Code (NX1200AV:K2). I double checked the Kenwood price pages to make sure my rep didn't sell me the wrong software, and all I see on the 1200AVK page listed is the D6N software. Has anyone else ran into this problem? Is it something simple I'm overlooking? The version I have is 1.11. Not trying to use NXDN/DMR, just simple analog use.
tp636radio
Update: I found the solution, you need to first update the firmware on the radio for DMR or NXDN (I chose NXDN). After the radio rebooted I was able to write to the radio from the KPG-D6N software. Hope this helps someone!
There is a newer version of software that probably takes into account the new analog only radios. KPG-D6N V1.52 was released back in early August.
