- Joined
- Aug 19, 2014
- Messages
- 123
on my roof are 4 antenna...
a 4010 EFHW and a 10m/6m/2m/70cm vertical, attached to my IC7100
a dual band 2m/70cm, attached to my FTM400.
and a tram 1411 discone for my Pro197
they are all at least 8ft apart.
the base of the discone mast is a few feet lower on the roof than the rest which are at the peak, but it's so tall with the cb top whip that it reaches higher than the 2m/70cm for the FTM400 and the balun of the EFHW. but - the discone is easily the closest to the EFHW. 8ft away in the direct opposite direction as the wire, and the disc just below the balun.
so then i get my General ticket and i've been rolling through the bands on FT8 for the last 3 weeks, usually at 75w or more if i'm going for someone far away.
and when i'm not, sometimes i'll have WSPR running, which does spill in to 2m/70cm if you're rotating through all the bands, which i was... though usually have WSPR at a lower wattage.
so now i'm sitting here looking at my Pro197 and my FTM400 - the FTM400 is hearing a conversation on a local ham repeater on 146.850, the Pro197 is not.
but, if i hit WX the Pro197 picks up 162.550 instantly and clearly.
none of my 146Mhz channels are coming in...
so i reset the radio and manually add the 146.85Mhz repeater... still nothing... turn the squelch to nothing, wide open - it hears nothing - the FTM400 still hearing the conversation.
then i use Win500 to reload all my channels - instantly getting 800Mhz local trunked channels and 461Mhz conventional channels.
earlier i was hearing 6m traffic, made me wonder, so i picked up my CB and transmit on ch6 - picks it up loud and clear...
the FTM400 is hearing the local ham repeaters, my Anytone handheld is hearing local repeaters... but... not the Pro197.
so i'm picking up 27.025Mhz, 52Mhz, 162.550Mhz, 461Mhz, 800Mhz... but... it can't hear 146Mhz or anything in the 2m ham band.
WHY??
and really, I'm wondering if somehow I damaged the scanner with WSPR... but that's a max of 50w from 10ft away, so... not likely, right? possibly damage from FT8... but... would 100w of HF data screw up the receive of 2m traffic, and only 2m ham traffic?
it's an old scanner, if it's just age and wear, then so be it - it's been a great scanner - an amazing scanner - and aside from 2m ham still is.... but i'd like to figure out why. my concern is that somehow i caused this with other RF traffic. and i'd hate to save and plan and shell out for something like an SDS200 some day, only to cause it the same damage.
anyone have any ideas on how to test it or what could be the cause?
thanks & 73,
Richard
N0TZC
WHY??
thanks & 73,
Richard
N0TZC
