Will the high band channels still be used?
Zones 1 and 3 will remain on the VHF System in addition to their respective county systems. Zone 2 is now fully on CORNet.
Wonder aloud and speculate all you like, it doesn't change the fact that there are no dedicated talkgroups on CORNet equivalent to anything on EDACS for those three agencies. That's not to say that things can't change in the future, but currently those equivalent talkgroups simply do not exist.GTR, as you are likely aware, both Harriman PD (04-115 / 605) and Cornwall-on-Hudson PD (04-152 / 634) have their own talkgroups on NYComCo's EDACS. While I can't speak for Cornwall-on-Hudson, Harriman uses theirs quite regularly. I'm finding it hard to believe, though not impossible, that they would take a step backward and not be granted the ability to talk amongst themselves without disturbing their dispatching agency on their Tac talkgroup. Thinking aloud here, I suppose, if that does happen, each could switch back to their respective VHF-high band local government channels for car-to-car traffic (151.1000, 162.2 for Harriman and 154.9650, 136.5 for C-on-H). I suppose we'll have to wait and see what happens after each department finally transitions off EDACS onto CoRNet, along with so many of the other remaining east side PDs.
No issues with City of Newburgh PD's talkgroup that I can detect. You haven't given us enough info to even begin to suggest what the issue might be, namely what you're listening to them with.I'm in the City of Newburgh area. Listening to the police seems that I'm only hearing half of the conversation. Anyone know if I might have a setting wrong? I have the delay set at 5 seconds.
In the Import window of ARC536 under the Trunk Options tab, you can check the box to download all of the frequencies. As stated earlier, you only need the control channel and alternates.I have a question about programming this system. The database shows 8 channels for North Simulcast. When I download the system into ARC536 PRO, it only imports the last four channels.
South Simulcast database shows 7 channels, but only downloads the last four.
Am I missing something? Should I program the system like that?
Sorry, but what is the point of digging up and commenting on a post over 2 months after it has clearly been addressed? You've provided no additional info of value to his specific question.In the Import window of ARC536 under the Trunk Options tab, you can check the box to download all of the frequencies. As stated earlier, you only need the control channel and alternates.
Uniden SDS100. just seems to not all of the conversation at times. it might be meNo issues with City of Newburgh PD's talkgroup that I can detect. You haven't given us enough info to even begin to suggest what the issue might be, namely what you're listening to them with.
its set at 5 secondsIn the Import window of ARC536 under the Trunk Options tab, you can check the box to download all of the frequencies. As stated earlier, you only need the control channel and alternates.
Check that the scan delay is not set to a negative value (-5 seconds).
Well, that pretty much rules out a simulcast issue, as the SDS100 should be receiving the system solidly. Are you experiencing issues with other talkgroups, or does everything else seem like normal flow of conversation?Uniden SDS100. just seems to not all of the conversation at times. it might be me
Everything else seems to be OK. Have the same problem on 2 different scanners (both SDS100) that's why I thought it was something I was doing wrong. I don't what to listen to all the PD in the county. Is it best to avoid everything except the PD I want to listen to? OR Is it OK to create 4 different Favorites Lists for each PD and turn them ON/OFF when I want to?Well, that pretty much rules out a simulcast issue, as the SDS100 should be receiving the system solidly. Are you experiencing issues with other talkgroups, or does everything else seem like normal flow of conversation?
Are you scanning both the North and South cells (sites), by any chance? If yes, that could explain the gap in the audio, as the scanner is alternating between cells, and you're missing transmissions while the scanner does so.Everything else seems to be OK. Have the same problem on 2 different scanners (both SDS100) that's why I thought it was something I was doing wrong. I don't what to listen to all the PD in the county. Is it best to avoid everything except the PD I want to listen to? OR Is it OK to create 4 different Favorites Lists for each PD and turn them ON/OFF when I want to?
Thanks for everyone's help.
ThanksCreate different favorite lists. Then turn them on and off. I kind of do the same with my Unication split between East, South and West. In each of those I’ll also throw in Priority, SP and the SO since they are countywide per se. Then others are Fire/EMS, just Fire, just EMS, etc. To be honest I mostly leave it on Fire only but the quick key (or for me a knob turn) will bring it the other talkgroups if something is going on.
thanks Ill try thatAre you scanning both the North and South cells (sites), by any chance? If yes, that could explain the gap in the audio, as the scanner is alternating between cells, and you're missing transmissions while the scanner does so.
Figure out which cell is strongest in your location (probably South), and scan only that site. This will ensure the scanner dwells on only one site, and will drastically reduce the amount of missed activity.
Full credit to @k2hz for the suggestion that this could be the issue (mentioned to me in an email), as it didn't even occur to me to ask that basic question!![]()
The sites are correct.Is there any possibility that the site identifiers in the database are swapped? I live in Marlboro (just north of the Orange County line) and I'm picking up the 'south' system like gang-busters. No signal at all from any of the 'north' frequencies. Seems a bit strange...
Thanx.
Yes...no...maybe so!As a quick follow up GTR8000, do the North & South Simulcast the same transmissions?
