Have seen aprox 14 tg ids, and about 36 RIDS so far.
Sent from my SM-G935V using Tapatalk
I have yet to hear a single voice in the clear. The entire system is encrypted so far.
For practice try the Chautauqua Co. P25 system. You won't be able to get it from home but on PI or anywhere near the waterfront it should work with the rubber duck.
I set up the Chautauqua system in a new favorites list by appending it from the database. For some reason it only seems to be scanning the Simulcast site from the system, and nothing else. How do I get my 436 to do ID scanning of the whole system?
154.935 now has data on it, assuming to be p25 p2 as my p1 scanner can't decode it
What scanner? Is it a model that works with Unitrunker? If you can feed the control channel to Unitrunker, you can get all the pertinent info for the site.
What are the frequencies for Allegheny County and Westmoreland Counties? I will program them into my 436HP and keep a listen on them.
correction my 396 now shows DAT and LNK now that I've turned off the ctcss scanner and properly programmed the correct system into it
I'm getting a Cw id on 154.935 here in north Versailles.
