PA Statewide P25 Phase 2 System
HM1529
Pennsylvania DB Admin
West of the Atlantic Ocean
I'm still kinda new to the Phase II stuff and the 436 BCD, I know how talkgroups work, but not sure about the radio affiliations by talkgroups you've posted here. Are those the individual radios on the system that have shown up on those talkgroups? Do those users show up on the 436 display?
Radio affiliations and radio ID's can be found on most trunked systems...not just a P25 phase 2 system.
A radio ID (or RID) is a unique identifier for a radio on the system. You can see this pop up on a BCD436 when a unit transmits on a clear talkgroup. The BCD436 ignores encrypted transmissions.
If you are using some kind of system tracking software (like Unitrunker, Pro96com, or something else), you will see lists generated in real time of active talkgroups that have had a radio affiliation, voice, or data traffic. An affiliation just means that a radio has been turned to that channel and, in the case of this system, is registered with the particular tower site you are tracking. It does not mean anyone is talking. Voice transmissions are the only time you will see something pop up on your 436...although mine will stop briefly on an encrypted talkgroup when someone transmits sometimes (on my local county system)...just a brief pause less than a second. It will then resume scanning because of the encryption.
How is this stuff useful?
Talkgroups and radio ID's can be completely random. Although, most sys admins have some sort of pattern to it all. Based on the various postings and PM's from folks up in the NW, there appears to be patterns to the layout of the new system as far as talkgroup numbers and radio ID numbers. This is, of course, incredibly difficult to confirm since all of PSP is encrypted. Since other agencies may or may not be clear when they come on board, keeping track of these numbers is a good idea.
The air to ground 700 system is inconsistent when it comes to the talkgroup numbering, but there are patterns for the RIDS.
When things are organized, it can give you ideas as to who is who, even with encryption. For instance, RID's on federal VHF frequencies can help identify which alphabet soup agency the frequency is being used by if you've paid attention to the RIDS that show up in the clear on other known frequencies. The same sort of thing can be done with this system.
Also, with the geographic isolation of not having significant wide area simulcasts on this new system, you could even go as far as making a guess on which talkgroup ID belongs to a particular PSP station. Knowing there are three stations in Erie County and that there are maybe two talkgroups that show up on the Erie tower frequently with unique sets of RIDs, you can surmise that one is PSP Erie and the other is PSP Girard. If there is a third talkgroup that shows up on Erie tower and other nearby towers regularly, that could be Corry since they patrol the eastern end of the county. Then, a second lesser used talkgroup sharing RIDS with one of the previous talkgroups could likely be the station tac channel. If you see a talkgroup used periodically with RIDs from all the dispatch groups in Troop E, that would probably be E Tac 1. Right now, on Opensky, there are "troop tacs" instead of the old statewide tac 1, 2, 3 from the VHF days. But, again, with the fulltime encryption, confirming anything for PSP would be difficult without an official source of info.
Using voice traffic clues and RID's can help flesh out clear talkgroups, though. Seeing the same RIDS routinely on several talkgroups will most likely indicate they belong to the same agency. Sure, there could be some exceptions since there are some global statewide talkgroups that show up in all radios. But, historically, their used is exceedingly rare...normally just for special preplanned events. And, even there, you're most likely going to see agencies use their own talkgroups for their own agency specific functions. I thought for sure I would see use of the global talkgroups when I was working the Papal detail in Philly. But, DEP, National Guard, PSP, etc all worked on their own channels since they had distinct functions.
It helps a bit to know how agencies currently have their fleetmaps set up. But, even that won't be a perfect resource because agencies have been asked to review their fleetmaps and consider changes if they find there are talkgroups on OpenSky that have never been used or seem superfluous. So, going from the old system to the new system, there may not be complete matching of the fleetmap...it will depend on the agency.
scnrfrq
Erie, PA
Wow, thanks for the thorough explanation. I appreciate it. Could you clarify one thing about the 436? You mentioned that encrypted talkgroups don't show up at all. How then do the encrypted talkgroups show up in the RR databases? Are they only found by listeners using system tracking software? I guess I thought they would appear on the 436 display with a certain sound when users were transmitting.
I have the Erie County system set up as a favorite list. I won't have access to my scanner till this Friday, but it sounds like if I have it set for ID Search, I won't see any encrypted talkgroups, and it will only show ones in the clear. Is that right?
Railbender
NW PA
"Could you clarify one thing about the 436? You mentioned that encrypted talkgroups don't show up at all. How then do the encrypted talkgroups show up in the RR databases? Are they only found by listeners using system tracking software? I guess I thought they would appear on the 436 display with a certain sound when users were transmitting."
On my 536 I get a garbled audio sound when receiving an encrypted transmission with the talk group displayed. Not sure what the setting for that is but it must be there somewhere. I have the 536 in record mode while running the TRX-2 with Pro96Com for logging.
Railbender
NW PA
Is anyone seeing any of these talkgroups, other than 12000, on other sites?
Talkgroup List for Erie site
as of 10/10/2017
10001
10002
10011
10026
10027
10028
10065
10078
10091
10101
10127
10128
10129
10130
10131
12000
scnrfrq
Erie, PA
I have the new system set up as a favorite list with ID Search. The Quick Key is on for this favorite list. I had this working with my 436 before vacation, but now when I turned it on it's not doing the ID Search. I have 3 sites set up and before you could see it searching all 3 sites sequentially. Now I get this on the display:
Unknown
No Stored TGID
And Hold in the right lower corner.
It is sitting on just one site and not changing. How do I fix this and why would it change after being off for 2 weeks?
scnrfrq
Erie, PA
Unknown
No Stored TGID
Just noticed - seems like if I remove the antenna it does ID Search as it should. What does this mean?
troymail
Silent Key
Unknown
No Stored TGID
Just speculation on my part based on things I've seen from time to time:
- possibly: the radio rebooted itself at some point...my 436 and 536 are always recording and storing on the SD card and eventually, if the SD card is larger than 4Gb, the radio chokes and reboots. When the radio reboots, some settings that are only "in memory" and/or those not saved by performing a radio shutdown (which seems to be the only time some settings are stored) are lost
- I've seen the "unknown" and "No Stored TGID" and from what I recall this seemed to be associated with location settings being enabled and/or bad or missing location information (lat, lon, range) for the system(s) in quesiton
Again - just suggestions of things to check which may or may not apply.
scnrfrq
Erie, PA
OK - I did turn off location control - still no luck. If I take off the antenna, it does search all 3 sites like I think it should. I also adjusted the squelch with no change.
troymail
Silent Key
FTR - we went offline and I took a look at Tom's configuration and he adjusted two things:
- turned off location control - the sites in his FL had the default 0/0 for location
- recommended adding at least one department (group of talkgroups) to his configuration and assigning at least one talkgroup (even a dummy of 9999)
It seems things are a bit better now but I'll wait for Tom to post his results.
scnrfrq
Erie, PA
I did turn off location control. I then went to another system. When I went back to the PA P25 the ID Search was working. Listening today for the first time. Hearing clear voice on TG 12000. Heard Harrisburg talking about reprogamming some radios. Not sure how I could hear them from Erie? That's all I've heard so far. No encrypted TG's yet.
troymail
Silent Key
Great to hear things are improving....
As far as haring users from Harrisburg talking up in Erie, that's the nature of the statewide system. I'd guess that there is at least one radio on an Erie site that is turned on and affiliated with/switched to TG 12000 that is also active in Harrisburg.
Once active/operational, the system should support users talking (likely on selected talkgroups - not all) from all corners of the state - and possibly even beyond.
When the Maryland FiRST system was just coming on line several years ago, Motorola did some type of demo where they connected radios in Maryland (on FiRST) to Motorola users in the Chicago area....
On a related note, Hams using DMR now using digital and repeaters to communicate worldwide as if the two users are right next door to one another.
scnrfrq
Erie, PA
Also just heard encrypted TG10001.
Railbender
NW PA
That was 130 Harrisburg responding to units 124 & 135 when they could not reach Franklin. I logged and recorded 115 hits on the Erie site today between 0500 and 1800. Most by TG 10127 ENC plus 38 clear voice by 12000.
talviar
Uniontown, PA
Not too surprising. If the Master site or Zone controller for the particular RF sites is already setup and installed somewhere- then Motorola sets up a path thru the IP connection that is already in place to the system and ties the equipment in that is in staging in Chicago area. At that point the equipment is on the factory floor into dummy loads. And is fully functional on the system. Just sitting in Chicago. . . . .
We did the same thing with the PA Icorrs system when Fayette was at staging as well as Lawrence.
Railbender
NW PA
Here is an interesting site information from the Erie site yesterday;
The first adjacent site, 107 on 151.3025 MHz is Cussewago. The second site, 116 on 151.2725 MHz is interesting. 151.2725 MHz was listed as one of the Erie frequencies early on (see post 25 in this thread.) but was not on WQWA746 when the license when it was issued.
scnrfrq
Erie, PA
Only voice I've heard so far is on TG12000. Not sure if this is just testing, or if the Game Commission is active on it full-time now. Other encrypted talkgroups I've heard have already been listed here. I'm starting to Avoid those now.
My main interest is in DCNR and if the Presque Isle rangers will be encrypted or not. Guess it's too early to tell?
Railbender
NW PA
The game commission is actively using the system. There has been extensive testing on the encrypted TGs the past couple of days however most of it has been by only 4 radios, and between 0800 and 1700.
HM1529
Each agency will be on their own timeline for migrating and it will be based on available funding for new equipment. So, I would expect to see continued addition of new users over the next few years in the NW and SW as field equipment is purchased, programmed, and rolled out to end users.
Since each agency is doing the buying on their own, it'll take time.
