All,
I'm still curious to see how everyone is setting up their Uniden scanners. What I've done so far is create a system for a county's Safe-T frequencies/channels as well as a system for conventional freqs. Inside each are separate groups (Fire, EMS, Police, Sheriff, State Police, etc).
Does anyone have any suggestions, best practices, examples, etc. of how they've programmed their Uniden scanner for Safe-T and conventional? I plan to use mine while mobile and before I start throwing everything I can find in it, I'd like to make sure I'm setting it up in the most logical manner.
Also, here's a Safe-T related question. Monroe County has 3 different Safe-T towers (Bloomington, Paynetown, and Hindustan). With my setup, I have only included the Bloomington tower and not the other two. Should I be including the other two towers in my scanner configuration? If so, should I be locking them out and just enabling them when needed?
I'm still getting the hang of programming my scanner. I do use FreeScan and import from the RadioReference database. Any thoughts or suggestions on the matter would be appreciated.
I personally would put in all of the towers. That way if what you are wanting to hear is not being broadcast on the Bloomington tower due to not having a radio affiliated, you will be able to hear it off the other two towers.
