Radio shack pro 652
AngWay
Curious
Elizabethtown Ky
Can someone explain exactly what a DC block does, i know it says it blocks DC voltage from your radio but i still don't understand, Like i use a LNA and i'm using a two way splitter that goes to my sds100 and my rtl-sdr i use a compleatly different antenna that goes to my pro 652 and the scanners are beside each other, so what would something like This do to help anything at all or would it do nothing at all. i get it blocks dc voltage from the radio but what does that do for performance? Thanks
AngWay
Curious
Elizabethtown Ky
I tried searching for what contrast means under the global settings but i couldn't find anything, this is all the manual says about it.
For most numeric entries (except Contrast) simply enter the new value and press F1 (Done).
For most selectable entries (like Yes, No, On, Off, etc. and Contrast) use the ◄ or ► keys to select the new parameter.
I don't understand what it means if anyone with more knowledge than me knows please help. Thanks
GTR8000
NY/NJ Database Guy
BEE00
Here's a thought...why don't you adjust the contrast setting while looking at the display and see if you can figure it out for yourself.
The amount of time you spend asking endless questions on this forum could be better spent learning some basics and actually getting physically familiar with the stuff you own.
AngWay
Curious
Elizabethtown Ky
It's not that kind of contrast
AngWay
Curious
Elizabethtown Ky
If by "that kind of contrast" you mean it's not the LCD display contrast, well then that just shows that you really don't put much effort in on your own before asking questions here, because that's precisely what kind of contrast it adjusts
I'm sorry You are right i apologize i need to search more before i ask questions. Thanks for pointing that out.
AngWay
Curious
Elizabethtown Ky
Hey does anyone know how i can covert the date from my pro 652 into data i can upload to the sds100? the files in the pro 652 are .P500 and .bin files and i would like to be able to upload my 652 data to my sds100. Thanks
dave3825
Suffolk County NY
Copy and paste from one to the other or create an excel sheet that takes copy from pro 652 and manipulates It to unidens format and then paste into sentinel. Similar to the freescan converter someone wrote years ago.
AngWay
Curious
Elizabethtown Ky
I tried copying everything in win500 and pasting them into sentinel but it just gives me a error.
AngWay
Curious
Elizabethtown Ky
I was able to do a copy and paste from PSREdit500 to sentinel but everything copied except the name. and i can't isolate the name in psredit and copy to sentinel
dave3825
Suffolk County NY
Post a PSRE file. Likely something with the format in that column. Might be extra space or something.
