During a wildland event are the County XSD command and tacs in use at all, or are they just a fallback in the event of a RCS failure?
good info thanks
Just to add, there was a small vegetation fire in Santee last night. Heartland assigned XSD Command 2 and XSD Tac 1. All responding units responded on XSD Command 2, and there was zero traffic related to the incident on RCS. So I think programming the XSD Commands and Tacs is a must to not miss wildland incidents.
Entirely possible. I will check it out tonight. Thanks for the feedback.Hi Celbaseman. The San Diego County Wildland Fire Operations VHF feed volume seems very very low. I tried maximum volume on two devices and can barely hear it. Thanks for the great feed!
Pardon the derail, but where in Poway is your antenna? Seems to have pretty decent coverage. I'm also in Poway, but down in a hole.As for Heartland, if the call is for a wildland/veg fire, automatically will go to XSD channels. Santee had a couple yesterday and were on XSD channels plus wildland training has been on XSD channels with Mirimar communications the past few days.
Plus, I turned up the volume on the SD County Wildland Fire Operations VHF radio.
Got it. Well, it sounds better than I can usually hear from the Twin Peaks/Community area. Kent Hill blocks me one way and the ridge along Palisades the other.@firemanjohn, I am not far from the bowling alley area. Kind of in a hole too, but a little bit up on the hill. The radio is connected to a 2m 440 antenna on the roof so pretty good coverage as far as receiving the VHF repeaters.
