- Joined
- Aug 1, 2011
- Messages
- 893
Just tried this run on the 436 and I still am hearing nothing through the PC just the scanner. Is this how it works? Giving us just a display and the ability to hear what channel is talking through Text to speech or is there something I have wrong here?
I also just tried it with the HP-1 again and it still will not connect to the program.
Thank you for doing this either way. I love new things to try out. Especially when they come at little to no cost.
FWIW: Which probably will not be much as these would be just over-sites on your part.
I'll assume you have put a check in the box for Speech before you run the program.
Is your windows mixer set to play "what you hear"? Others may work too but that is what mine is on and it works for me.
Is you PC audio turned on and the volume up to at least 50%?
Can you play other things through your PC and get audio? Is the audio Mute on your PC on?
Have you tried a different USB cable and is it plugged into a USB 2.0 port? I have read that some USB 3.0 ports are not always 100% backward compatible.
