SDS100 Prerelease Discussion
milcom_chaser
Nobody in MY area (Los Angeles, CA and surrounding counties) uses DMR, NXDN, and such. I don’t care about listening to those ham repeaters that do, but no police, fire or EMS agency I listen to uses them, or is planning to.
"Nobody in MY area (Los Angeles, CA and surrounding counties) uses DMR, NXDN"
Are you sure? Click this link, https://digitalfrequencysearch.com
fill in LA County, Ca.
milcom_chaser
Don’t forget that the SDS100 is also supposed to have superior decode on weak digital signals.
In addition, if it does have an RSSI read-out I may be able to finally use my 8 element 800 MHz Wilson beam to find the best direction to point it in. At present, it takes such a small signal to give five bars of signal strength on my 436hp that this has proven difficult.
You may not need that Wilson Beam with this radio's ability to decode LSM...
RF23
According to the Rafael Micro R836 Spec Sheet you posted, the minimum operating temperature for this tuner appears to be only 0 degrees C or 32 degrees F.
The winter temps in the northern U.S. would be a real challenge for this tuner.
trp2525
Not sure where the $100 came from. Parts costs more than that. Add royalties. Add production labor. Add engineering cost. Add sales and marketing cost...
Not sure where that arbitrary $100 "cost" for the SDS100 came from either. That figure is certainly WAY too low when you factor in everything that is involved in R & D, production, sales, support, etc.
For comparison purposes I have some information regarding what Whistler invoiced Radio Shack to produce their PRO-651 and PRO-652 scanners. The following information is from the Radio Shack/General Wireless bankruptcy court proceedings which is readily available online.
Whistler's invoice cost to Radio Shack for the PRO-651 handheld scanner (same scanner as the PRO-106 and the GRE PSR-500) was $165.00 with 3,600 scanners ordered/produced. Radio Shack's MSRP for the PRO-651 was $400 (which was their regular selling price) and it frequently went "on sale" for $300.
Whistler's invoice cost to Radio Shack for the PRO-652 desktop/mobile scanner (same scanner as the PRO-197 and the GRE PSR-600) was $161.00 with 2,730 scanners ordered/produced. Radio Shack's MSRP for the PRO-652 was $400 (which was their regular selling price) and it frequently went "on sale" for $300.
Of course Radio Shack had to pay the added costs for their sales and marketing costs for these scanners as well as any warranty repair/replacement costs involved. Also keep in mind that the above invoice prices were from 2015 so that also has to be considered as the prices would more than likely be higher in 2018. Here's the direct link to the actual Whistler invoices to Radio Shack (pdf file) if you want to have a look at the information yourself: https://cases.primeclerk.com/generalwireless/Home-DownloadPDF?id1=NTY0NTYz&id2=NTA1ODY5
springtx
Spring Tx
There were a few who said they would have some Video up this weekend but looks like nothing was posted.
WX4JCW
Stow, Ohio
I couldn't find too much information (other than the specs) for the R836. Is it currently in the guts of any available SDR product? I know it's a new successor.
It’s in the guts of several well known SDR’s
I have 2 RTL-SDR’s and an Airspy Mini
Sent from my iPhone 8 using Tapatalk Pro
Jason WX4JCW
Unication G4, BCD536HP
jcook11
Central IL
I don't think it is in any of the current SDRs but the current tuner that most of them use is going obsolete and this is one of the alternatives. From the Airspy list:
"Rafael Micro officially discontinued the R820T2 since a few months. This is the tuner we use in the Airspy R2 and Airspy Mini."
"The newer tuners are slightly better (lower NF, more DR), but are also more complex and require a lot of work to get right."
eorange
♦RF Enabled Member♦
Cleveland, OH
Thanks, I came to that same conclusion on the R836. Just wanted to be sure I wasn't missing something.
jasonhouk
Marion, Ohio
