CanesFan95
Analog already is interoperable.
Its a quirk with all Uniden DMR scanners, Upman has confirmed they won't change it and won't even add resume as an option, their heads are buried deep in the sand.
It makes autonomous operation near impossible it will hang on custom search, scan with search or if you get a DMR signal on a conventional channel.
If, like me, you want this feature you'll have to stick with Whistler or AOR.
It seems awkward to have to program conventional DMR frequencies as a trunking system to really make it work. Tier II isn't considered trunked, is it? I would rather it know to just keep scanning if it's not a voice call and let me program in the slot and TG ID with conventional DMR frequencies. Conventional DMR doesn't have system IDs, does it? To see the slot, color code, & TG ID, you could just hold on the frequency and look on the display. But if you already know the slot, color code, & TG ID, then it would be nice to be able to program that in and not have it hang for non-voice data.
