Got to the monitor and test tab and click loop back.
Yes you can do all that you are wanting to do and you are going to love the Proscan / SDS200 combination. I love being able to control and listen to my SDS200 hooked to my outdoor antenna anywhere I am, even on my cell phone if I want. Most of the time I'm controlling it from a third monitor in my office at work. Response time on commands with RSOIP is nearly instantaneous.Good to know. Just trying to get use to this software and dialing it in. Next thing will be is to setup the port forwarding and get my radio to see the outside world for me remotely. This will be the next step this weekend. Thanks
No problem at all glad to help out.Thanks. Found it.
Use the computer IP address, and the port the RSOIP(or Web Server) is set at, and TCP only. That's it.My question is do I do the port forwarding of the radio static IP address or share out the port forwarding of my computer that its hooked up to?
I have a mesh network EERO nodes and I can make changes on my app on my phone. On the port forwarding its giving me the external port and internal ports I can give it a numerical numbers for both. Also, I can choose the protocol eith TCP & UDP, or just TCP or just UDP.
One last question and I think its all working but I am seeing my radio and its scanning along on the internet using the ProScan client but no sounds is coming out but I see the radio scanning.
It's just an IP address. What's wrong with it?Where is God's name did you come up with that static IP?
I hooked up my BCD996P2 radio and it works and scans but no sound either. I get this error message in Proscan. I was able to hear audio earlier on the loop back but never remotely. View attachment 69573
Just a bit odd most often they areIt's just an IP address. What's wrong with it?
Had the same problem awhile back. Used revo Uninstaller to remove the program. Reinstalled and all worked fine. Not sure if that will help but just throwing it out there.I hooked up my BCD996P2 radio and it works and scans but no sound either. I get this error message in Proscan. I was able to hear audio earlier on the loop back but never remotely. View attachment 69573
192.168 0.xxx
Or
192.168.1.xxx
Sent from my SM-N960U using Tapatalk
