Selfridge Air National Guard
Hooligan
Clark County, Nevada
The others were found using regular search mode on 3 scanners at home. Each scanner searches about 50Mhz each in the Milair band. 225. to 380.
Hey Chuck, I hope you'll go back to searching the full 225-400MHz, as the 380-400MHz is definitely not just used for LMR (as Philip's 388.2Mhz logging shows). Also of course 30-88 & 138-144 & 148-150.8MHz.
Here's a photo of the main comms antenna used by A/OA-10s. It's good for 30-400MHz AM/FM & SATCOM with the Warthog's AN/ARC-210 radio.
AFO
NW Pa
PRESET 12 326.000 TEJAS 21&22
I'm guessing this is preset 11 273.000 DEMON 11
PRESET 13 307.600 YALTA 31, (BOSON 41 & 42, they said to make sure HOWDY knew they were on 13 not 14 01/30/13)
PRESET 14 368.000 (BOSON 41, 42, & HOWDY 51? 01/30/13)
I'm looking for Toledo's also
248.65 Sting & Buzz 51,52
357.1 Buzz
367.5 Bucki
312.5 Buzz 21,22
nodak1crdet3
Detroit, MI
MTC A-10C Presets.
357.1 Buzz
367.5 Bucki
312.5 Buzz 21,22
Hi AFO
You are correct on the Presets for the Selfridge A-10's.
UHF & VHF presets. AM Mode.
361.250 143.750 BTN 01 DEMON Ops. UHF New (11-09) VHF New (06-08)
259.950 119.000 BTN 02 Clearance Del.
275.800 128.300 BTN 03 Ground.
225.400 120.150 BTN 04 Tower. New (06-08)
391.900 119.600 BTN 05 Departure (07-09)
318.200 119.600 BTN 06 Approach. (05-09)
290.425 127.700 BTN 07 Cleve.C.
234.900 000.000 BTN 08 BLACK TALON Alpena CRTC, UHF.
269.450 118.525 BTN 09 Minn.C. (07-09)
266.600 000.000 BTN 10 R-4201 Grayling Range STEELGATE CONTROL.(07-09)
273.000 000.000 BTN 11 DEMON 11 A/A
326.000 000.000 BTN 12 TEJAS 21 A/A.
307.600 000.000 BTN 13 YALTA 31 A/A
368.000 000.000 BTN 14 BOSUN 41 A/A
388.200 000.000 BTN 15 IFE Emergency freq.
234.800 000.000 BTN 16 DEMON SOF (Supervisor of Flight 03-26-10)
254.700 000.000 BTN 17 PIKE MOA traffic, TAC / ACM CH (01-10)
225.300 000.000 BTN 18 STEELHEAD MOA traffic, TAC / ACM CH (02-10)
314.400.000.000 BTN 19 HOWDY 51 A/A
270.100 125.325 BTN 20 ATIS.
Might not be hearing the A-10's for a little while. I've heard they went to Davis Monthan AFB in Arizona for some training.
Toledo F-16's
248.650 STING A/A AUX 06
357.100 BUZZ A/A AUX 08
I will have to check out that 312.125 freq you caught. Nice job on the new freq.
AFO
NW Pa
These are some of the other new hits i got this year too
233.7000 Base Ops Wheeler-Sack Army Airfield, Fort Drum, New York Base Ops reach 428
234.8000 demon
251.2000 McGuire Field (Joint Base Mc Guire Dix Lakehurst) Airport 108 ANG COMD POST(TORCH CONTROL) FT DRUM RANGE NY moa tomcat 4
251.9000 demon 12, roadhouse, disco
267.8000 Battle Creek ANGB 110TH FG (Battle Ops) CP boxer 45, sluff 91-battle ops, steel 81
297.9000 Eastern WV Regional Airport/Shepherd Field, Martinsburg KMRB GALAXY callsign for Command Post / PIKESIDE callsign for Base Ops CP reach 209, Decoy 99 / SWEDEFORCE QUEBEC01 flight of 8 Gripens Air-Air
305.4000 Air-Air indy 83,84
305.5000 Aerial Refueling Track 219 Primary AR claw 12, 4135 _ 79-0433
313.5500
314.1000 AR SWEDEFORCE QUEBEC01 flight of 8 Gripens AR with reach 61
322.8000 Air-Air SWEDEFORCE QUEBEC01 flight of 8 Gripens
343.5000 Aerial Refueling AR-608 / AR-109H primary AR
371.9000 ARTCC - Minneapolis loma 11
383.3000 Quonset State Airport RHODY Ops RI ANG C-130
388.0000 app??? voodo 61 ??
