SNACC P25
coolrich55
connecticut
Staying center strip again this year. Last year I had the apex peak site programmed with the old analog system and I was able to hear everything. Should I program the same apex site with the new P25 system? Or the Las Vegas simulcast.
I use the p25 simulcast site work great for me, I hear everything with no problem.
kd7mxi
north las vegas nv
1537/2051/2563/2565/2571 ,,, tgs heard in Laughlin ,,, cant find 2051 in database ,, sounds like car to car maintenance of some sort .... hearing talk of fixing gates/pumps and building numbers
another unknown tg heard from Laughlin ,,,, 2065
P25 Sites
Here are the sites with the Control Channels I would like to confirm the site locations and the channels associated with the sites, I have 3 sites channels confirmed I believe
Site 002-020 853.225 Arden Peak?, Hear Henderson only on this site
Site 002-021 859.9375 Not sure on site location
Site 002-022 ??
Site 002-023 853.3375 Not sure on site location
Site 002-024 853.05 Not sure on site location
Site 002-025 853.05 Not sure on site location
Site 002-026 852.975 Red Mountain?
Site 002-028 852.45 Not sure on site location
Site 002-030 859.9625 Not sure on site location
Site 002-031 852.800 Not sure on site location
Site 002-033 853.900 Simulcast
Site 002-022 ??
Site 21 Apex
Site 23 Angels peak
Site 24 Big Horn
Site 25 Lake Mead
Site 26 Potosi
Site 27 Beacon
Site 28 Spirit Mtn
Site 29 Oatman
Site 30 BC W Tank
Site 31 lake LV
Site 32 W Site 800
Site 33 Simulicast
Elkhorn is suppose to be another Simulcast
Update
Site 20 Mandalay Bay
Site 21 Apex
Site 22 Arden Peak
Site 23 Angels peak
Site 24 Big Horn (Primm)
Site 25 Lake Mead
Site 26 Potosi
Site 27 Beacon
Site 28 Spirit Mtn
Site 29 Oatman
Site 30 BC W Tank (Boldercity Water Tank)
Site 31 lake LV
Site 32 W Site 800
Site 33 Simulicast
Elkhorn is suppose to be another Simulcast site. site number and staus unknown
coolrich55
connecticut
This info might be useful for any tourists staying on the strip. It seems to depend where you're staying as to what site to use. I stayed at the Flamingo and Cosmopolitan. While at the Flamingo the strongest signal was the Arden Peak site I believe. And the best at the Cosmopolitan was the Apex site. Both of those had every agency on it. There was another site, Mandalay Bay maybe, that was strong but only had Henderson. The LV simulcast site was weak at both places and didn't work well.
kd7mxi
north las vegas nv
i like using one channel modes in my uniden ,, all related voice freqs in each setup ,,, I load up all the voice channels I find wen I do search mode with p25 checked ,,,, nac codes get auto stored ,,, I program each setup by nac number ,,, I found there are separate nacs on the Laughlin/bullhead sites ,,,, 851.275nac468 ,,, 851.450nac468 ,,, 858.4625nac469
852.450=0461h-0228 ,,,, 854.1625=0461h-0229
I don't setup regular p25 trunking
coolrich55
connecticut
That's why I love my psr 500. Very easy to program. It took me a matter of minutes to figure out what was best. And when I did it worked perfectly. Also my pro 668 was perfect for lvmpd.
ScanWare
Full Time Elmer & Getting Paid to Play with Toys!
Las Vegas, Nevada
I just moved to Las Vegas have used scanners for years I have to homepatrol 1. Both scanners show plenty of channels in every area but I get almost nothing am I missing something here. I've driven all over the place and still get nothing even the GPS brings me nothing any help would be appreciated thanks
737mech
Clark County, NV.
Vegas Help.
I don't have a homepatrol 1 but I know it's based on the rrdb correct? Have you updated the database in the scanner? The old Clark County system recently changed, now it's all digital P25. Listed in the rrdb as SNACC P25 System. Also check your settings over. Range/Att/etc'. If all else fails make sure antenna connection is good. You should hear something this is a scanner busy town. You won't hear Las Vegas Metro Police on that scanner. They are on a phase 2 system. Youi'll need Homepatrol 2 for that.
I don't have an HP1 either, just some ideas and suggestions is it programmed for the P25 system, can you go in and check the control channels and see if they are correct and change them if they are correct, are the talkgroups programmed in or turned on.
Turn on ID search and see if it works also.
There are 2 SNACC Systems the old is not active much anymore, everything is on the P25 system now.
MtnBiker2005
San Diego County, California
Here some of the info for these sites.
___________________________________________________________________________
-TowerInfo
System ID : 461
WACN : BEE00
Tower Number (Decimal): 2-33
Tower Number (Hex) : T0221
Control Capabilities : Voice,Registration
Flavor : Phase 2
Timestamp : Tue Jul 5 08:03:26 2016
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"00-0039","v",851.25000,"00-0039",806.25000,0,21
"00-0063","v",851.40000,"00-0063",806.40000,0,18
"00-0087","v",851.55000,"00-0087",806.55000,0,17
"00-0103","v",851.65000,"00-0103",806.65000,0,18
"00-0199","v",852.25000,"00-0199",807.25000,0,18
"00-0223","v",852.40000,"00-0223",0.00000,1,20
"00-0257","v",852.61250,"00-0257",807.61250,0,18
"00-0305","v",852.91250,"00-0305",807.91250,0,19
"00-0331","a",853.07500,"00-0331",808.07500,1,0
"00-0349","v",853.18750,"00-0349",808.18750,0,15
"00-0383","v",853.40000,"00-0383",808.40000,0,18
"00-0423","v",853.65000,"00-0423",808.65000,1,19
"00-0451","v",853.82500,"00-0451",808.82500,1,15
"00-0463","c",853.90000,"00-0463",808.90000,0,0
"00-0529","v",854.31250,"00-0529",809.31250,1,15
"00-0545","a",854.41250,"00-0545",809.41250,1,0
"00-0593","a",854.71250,"00-0593",809.71250,0,0
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency
220,"T0214",461,"00-0355",853.22500
221,"T0215",461,"00-1429",859.93750
222,"T0216",461,"00-1353",859.46250
223,"T0217",461,"00-0373",853.33750
225,"T0219",461,"00-0327",853.05000
226,"T021A",461,"00-0315",852.97500
230,"T021E",461,"00-1433",859.96250
-TowerInfo
System ID : 461
WACN : BEE00
Tower Number (Decimal): 2-24
Tower Number (Hex) : T0218
Flavor : Phase 2
Timestamp : Tue Jul 5 09:51:14 2016
NAC: 46A
-Frequencies
"00-0231","a",852.45000,"00-0231",807.45000,0,0
"00-0327","c",853.05000,"00-0327",808.05000,1,0
-Neighbors
-TowerInfo
System ID : 461
WACN : BEE00
Tower Number (Decimal): 2-20
Tower Number (Hex) : T0214
Flavor : Phase 2
Timestamp : Tue Jul 5 08:08:03 2016
-Frequencies
"00-0177","v",852.11250,"00-0177",807.11250,0,4
"00-0229","v",852.43750,"00-0229",807.43750,1,5
"00-0311","a",852.95000,"00-0311",807.95000,0,0
"00-0355","c",853.22500,"00-0355",808.22500,1,0
"00-0977","v",857.11250,"00-0977",812.11250,1,5
-Neighbors
233,"T0221",461,"00-0463",853.90000
bryan_herbert
Las Vegas, NV. DM26jc
My BCD436HP became awfully quiet last week, when I looked at it closely I noticed I was not receiving Simulcast at all. I put my BCD396XT on Pro96Com and noticed several new freqs attached to not only Simulcast but also Apex. I gathered what freqs I could and submitted them to the database.
I left a couple freqs out unintentionally, I plan on running Pro96Com through Sunday evening and will resubmit all of the freqs I collect to the database on Monday.
737mech
Clark County, NV.
Henderson Hospital?
Has anyone found the new TGID for the new Henderson Hospital yet?
