2023???
2022 2023 whatever it takes.. 😎
2023???
Yes. Also, at least one "downstate" Troop is reportedly simulcasting traffic on both primary and secondary TGs.
On Sunday 1/1, "lu81fitter" posted to the ISP Restructuring for 2023 thread that the Troop 2 Primary and Secondary TGs were being simulcast.Have not seen that yet here in "downstate."
What troop is it?
Thanks.
Greg
Can confirm 13009 with Troop 4 (ex-D14) and 13011 (ex-D20) with Troop 6. Both patched to the primary at some point today for alerts. Also looks like Troop 5 is using the old D6 Car to Car 13044.Still need to confirm Troop 4 secondary (former 21A, 13009) and Troop 9 secondary (former D20A, 13011) talkgroups.
i am located in marion County i do hear 17006 (old 13A dispatch)and occasionally 17014 ( 22A) from my local tower near Centralia.Running especially low on resources for confirming ISP Troop 10 (former ISP Districts 13, 22 and Saline and Gallatin Counties from former District 19). No replies yet, and no Broacastify recordings available for the former D13A and D22A talkgroups (17006 and 17014 respectively). Is there anyone in or near the far Southeast portion of Illinois that could give those talkgroups a listen and report back?
i hear 17003 (old D12A)& 17011(old D19A) in use for Troop 9Happy New Year! Database admins are in the process of posting confirmed Illinois State Police Troop talkgroups to the Radio Reference STARCOM21 database page, but we need YOUR help! Active talkgroups heard so far for Troops 1,2,3 and 8 have been posted, but we need confirmations for what's in use for Troops 4,5,6,7,9 and 10 as well as any confirmed talkgroups not already posted for Troops 1,2,3 and 8. It appears that there are no changes anticipated for Troop 15 (the former District 15).
Initial information about the Troops, the counties they cover and the the primary/secondary talkgroups they are slated to use are posted in the ISP wiki. There could be other former ISP district talkgroups (car-to-car, etc.) in use as well.
Please submit what you're hearing via the STARCOM21 database page so the rest of the Troop talkgroups can be posted as well.
Thanks!
ISP Troop 6 is currently patching 13004 (former D9:A), with 13011 (former D20:A), which is causing havoc with the repeaters both simulcasting the patch as well as the original transmission on separate channels. Repeater is also sending out random bursts of data on those talkgroups fairly regularly causing havoc with logs and recordings. Previously I've only seen this issue with Sangamon County Sheriff patching their channels together for their alerts causing these random data bursts.
All current TalkGroups will remain in place, and will be renamed (see new config below). Each troop will use the current "A" TalkGroups from each current District as either Primary or Secondary. The lower of the 2 will act as the new "Primary", the higher of the two will act as the new "Secondary". Not all troops will use the Secondary talkgroups 24/7, however I would assume during high loads they will.
Examples:
Troop 1:
Troop 2:
- Primary (Current District 1A)
- Secondary (Current District 16A)
- Primary (Current 7A)
- Secondary (Current 17A)
Exceptions:
Troop 7 (Current D10) won't have a secondary TG. Until configurations are completed, current "B" TalkGroups will be utilized.
Troop 3:
- North: D2-A
- Middle: DC-C
- South: DC-D
- Southwest: D5-A
- Admin/Other: DC-A
EDIT: I replied in a post below, this came directly from a contact, who was notified of the change by the state.
Yeah, I understand that, its more that currently their dispatcher has their console patching both talkgroups as well as transmitting separately onto T6:A, causing 2 total transmissions to happen on two channels, one transmission being T6:A, the second transmission being a patch of T6:A & T6:B.
Observations gathered so far about the new DuPage County SC21 RIDs can be found here, starting with RID 10006585.Picking up new UID's on DUCOMM 3 south and hearing "radio checks" consistent with what ACDC has rolled out with thr APX Next radios.
