hai_akeeba
Bissell Hospital 772.90625 SID 001h-0303
No scanner on the market right now can trunk track a P25 Phase II system.
Wirelessly posted (BlackBerry8530/5.0.0.508 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
I went to load the system into the psr500 using win500 and when I went to load it. It said psr500 does not support this kind of system did I do something wrong
I got the same message when I tried to set up my new Pro-106 with Win500. Does anyone have a fix or change that should be made. As other posts have said this is not now a Phase 2 system. Possible change in the RR database needed?
Dave Paul
No problem here. Using Win500 and PSR-500. When programming system, system type should be "P25", and the Band Plan should be set to "700 MHz."I got the same message when I tried to set up my new Pro-106 with Win500. Does anyone have a fix or change that should be made.
