Sticky Thread For MilAir VII (2012)
coronet
Coronet deployment
Good evening,
Six F/A-18s enroute from MCAS Beaufort to Lajes diverted to Atlantic City, NJ this morning.
They should be departing tomorrow (Sunday) at 1100z as TREND 71-76 with KC-135 GOLD 24.
Hope this helps,
René.
zerg901
yup
Tuff 71 direct Hancock (near Ulster NY) - 215 PM EDT - from Concord NH - apparently is a B2 that did a flyover at the NASCAR trace in Concord / Loudon NH - 348.70 AM for ATC - just switched to 360.6
Tech792
Central NJ
Good evening,
Hope this helps,
René.
Briefly caught TREND and GOLD yesterday morning on ZDC 281.45
Tech792
Central NJ
09/24/12
Sounds like YANKEE Cap is up for the annual meeting of the minds at the UN. 260.9
harryferg
Hearing what sounds like DRAGON (?) flight w/ ZNY on 282.300 (15:45 local). From 290.200
Tech792
Central NJ
NY Yankee CAP
1730 local- Hearing SPAD 21/22 gassing up on 260.9.....I'm guessing F22s out of Langley
Tech792
Central NJ
NY Yankee CAP 09/24/12
2030 local- NATION 03 is the tanker on station
Tech792
Central NJ
NYC Yankee CAP
09/25/12
0535 local- SPAD 12 declaring IFE due to left engine shut down for an oil problem. Requesting direct to Dover AFB. SPAD 11 will follow 12 into Dover then direct Langley.
Tech792
Central NJ
NYC Yankee CAP
09/25/12 at 1115 local
sounded like SPAD 21/22 intercepted a small plane and were escorting to a small airport in Hillsborough, NJ.
nyair1
Devil Flt
Had a flt of 2 Devils NJ ANG up my way yesterday -
298.900 ZNY - Devil 11
273.550 ZBW - Devil 11 looking for entry into Viper MOA
323.000 ZBW - Devil 11 at 310. Will call MARSA with Cobra
226.300 - Devil 11 out of 310 descending into range 38
Sounds like they were doing some training up in the Adirondacs area and Ft Drum NY.
JohnFB
Western Mass
Large Coronet arrival @ KCEF Westover
26-09-2012
Btwn 2002Z & 2116Z 14 A-10's [I think] arrived @ Westover.
TREND 31 x4
TREND 44 x3
TREND 41 x3
TREND 53 x4
The only A2A I caught was on 138.200.
During the same time period I heard GOLD 91 & GOLD 01 check in with PACK Control [321.000] with inbnd msgs.
All aircraft were directed by A/D as individual flights due to local WX conditions, which is why it took so long to get them all on the ground.
All aircraft came in thru Albany, so I presume they are inbound.
coronet
Coronet East 130
26-09-2012
TREND 31 x4
TREND 44 x3
TREND 41 x3
TREND 53 x4
Yes, definately A-10s (354FS), they should be departing to Lajes from Westover tonight at 0400AM local
as TREND 31, TREND 41 and TREND 51 flight, supporting tankers are GOLD 81, GOLD 91 and GOLD 01.
René.
JohnFB
Western Mass
Cheers Rene ..... too bad I'm just reading this now ..... I cud have brought my handheld & listened to them @ break.
While on the subject of Westover, I heard what sounded very much like CHOSEN 1 x2 land there Thursday afternoon. Does DC still use that callsign?
TIA
mdmonitor
TIA
John,
The DC ANG F-16s haven't used CHOSEN callsign for years now. Their "travelling" callsign used to be BRAVE ## but that callsign is now used for real world scrambles & acty w/Huntress. So may they have resued CHOSEN for a travelling callsign.
nyair1
26-09-2012
TREND 31 x4
TREND 44 x3
TREND 41 x3
TREND 53 x4
John
Heres what i had from the Trend flt -
353.850 ZOB - Trend 21 flt of 4 Alpha 10's in the block 210-220.
353.850 ZOB - Trend 41 flt of 6 Alpha 10's in the block 190-210 non-standard.
372.000 ZNY - Trend 21 flt of 4 in the block 210-220.
372.000 ZNY - Trend 41 flt of 6 non-standard in the block 190-210 for direct
Westover.
138.200 - Trend a/a.
353.925 ZBW - Trend 31 flt of 4 Alpha 10's in the block 210-220 non-standard
would like direct Westover when able.
138.300 - Trend 51 flt a/a #1 has a oil problem in one engine and is going to be
shutting it down and declaring a IFE.
346.350 ZOB - Trend 51 flt with you block 180-190. 51 will be a IFE with #1
engine out. #3-6 will be going on direct to Westover, #1-2 will be going to
Syracuse.
346.350 ZOB - Trend 54 is now a flt of 4 and will be following the rest of the
flt plan.
372.000 ZNY - Trend 54 flt of 4 with you.
coronet
Coronet East 130
Hi,
TREND 31-36, TREND 41-46 and TREND 51-56 all departed from KCEF to LPLA today,
they are 354FS "Bulldogs" A-10s enroute to Afghanistan. This was their routing out of KDMA:
I see some references to a TREND 21 flight, they were never filed so I think this was in fact TREND 31 flight ...
They should be departing from Lajes to Sigonella this weekend.
René.
freqhopping
BOBCAT88 departing the area. 118.95>121.675
Seems to have a foreign accent.
JohnFB
Western Mass
[SNIP]
René.
tnx for all the replies. The A-10s started to depart KCEF around 0630L last Friday in 3 groups, going directly to the ACK ATC from Bradley A/D. DRAGON x2 departed the area a bit later. They were apparently the spares.
A2A seemed to fall into the 138.X00 range for all flts.
