Sticky Thread for MilAir
Rgr heard KANZA 94 McConnell Kansas got pressed into duty.Seems there has been all kinds of problems with CAP today.Not enough Tankers/fuel.Heard one ARROW had to land due to hydraulic problems.
KANZA 94 was emergency tanker I believe as he didn't know what or where GUARD DOG was.ARROW 23 told him was over Dulles airport area.
KANZA 94 now landing Willow Grove NAS with SHORTSTOP (Air Force Ops) 351.7500
requesting parking.
TinEar
Glen Burnie, Maryland
Mark, freq 270.275 is Potomac TRACON (Reagan National) which services Andrews. The low approach freq is 335.5.
Travis, what do those points on the Guard Dog map indicate?
This afternoon I took my trusty Uniden 785 out to the back yard, sat a magnetic mobile antenna on the picnic table and was able to hear all the CAP freqs loud and clear. That should indicate that nothing special in the way of an antenna is needed to hear the CAP. I was also able to hear aircraft with Andrews, McGuire and Dover. That surprised me - but only a little.
n3bxv
Severn, MD
:lol: Alan forgot to mention he lives in a magic spot where he can often hear things others can't:lol:
I on the other hand often hear things others can't -- but its only the voices in my head...
1949 <260.9> ARROW27, Looking for lower block due to weather... DC CAP
freqhopping
Except for the "anchor point" as they called it which is Nottingham and Camp D, those are the locations of the coordinates passed by Tanker-19 to KANZA-94 so they would know where to be to stay within the Guarddog airspace. They also explained their track as being 39 NM left legs, 14 NM wide with left hand turns.
TinEar
Guess I worked too hard outside today and am in a fog. You did say right above the map that they were the coordinates. Sorry for being dense.
1955: Current CAP participants are ARROW 27 and 28 along with TANKER 20. Due to weather, they are lowering the CAP altitudes...the fighters will be at 16 and 17,000 feet and the tanker at 19,000 with a transit altitude of 18,000. However, apparently there are storms approaching the CAP area and they say if they come into their area they want to be above it, definitely not below it.
ARROW 27/28 are working tac 369.15. This pair is calling that 8 AUX. Primary CAP freq 260.9 is 10 AUX. Looks like each flight decides where the freqs will go in the radio. The only one that has remained constant is 8 AUX for chat.
They have run into occasional fuel problems ever since Eglin fighters have been assigned to the CAP. They arrive with a low fuel load and need to be absolutely full when they leave for home because of the distance. The KC-135s just don't have enough fuel to handle it all at times.
2012: ARROW 27 is trying to weasel out CAP duty because of the storms. He asked HUNTRESS to confirm they will maintain the mission when the storms come through the area. «260.9» ARROW 27 is currently heading toward TANKER 20 for a fill up. «320.6». At 2026, ARROW 28 is heading for the tanker. Meanwhile 27 is reporting lightning strikes nearing his area.
2037: Now the CAP participants are moving higher because of the weather...they'll be in altitude block 25-28,000. «260.9»
2117: ARROW 27 is hooked to the tanker again to take 6500-7000 pounds of fuel. «320.6»
2124: ARROW 28 taking a turn at TANKER 20.
2126: ARROWs/TANKER/HUNTRESS changing primary freq to «228.9» because of noise on 260.9. HUNTRESS is loud and clear on 228.9 and I could just barely tell he was there on 260.9.
2131: ARROW 28 still closing on the tanker. Visibility is very bad so he's easing his way toward the boom very slowly. «320.6»
2139: And ARROW 28 finally makes contact with the boom. «320.6»
2139: TANKER 21 shows up and makes contact with HUNTRESS who tells him that the ARROW 31 flight is soon to arrive in the CAP. HUNTRESS give him the Mode 3s for the fighters and the tanker. «228.9»
2144: ARROW 31 flight checks in with Guard Dog on «288.35» to get clearance into the CAP.
There seems to be two HUNTRESS controllers...one I hear fine and can't hear the other. So...right now two pairs of fighters and two tankers are all in the CAP area and everyone is trying to avoid weather and moving all over - and out of - the CAP track.
2149: TANKER 20 clears out of the area and heads home. «135.525» He was handed off to Washington Center on 123.47(5) which appears to be another new freq.
2153: ARROW 31 and 32 heading for TANKER 21 to refuel but report "popeye" (eyes closed, blind, can't see ****). «320.6» They get no answer so go back to primary to see where the boom freq should be. They now decide to use «260.9» as a boom freq and move there for contact.
2158: ARROW 27/28 getting RTB clearance from Guard Dog «288.35»
Tail numbers for the new fighter pair:
ARROW 31--79-0041
ARROW 32--79-0026
We can presume EG for the letters.
2200: ARROW 31/32 report visibility only about 1000 feet in the area of the tanker. «260.9» ARROW 27 is over on «288.35» setting up a new CAP area because of the weather, then goes back to primary «228.9» to see if his flight can get out of there and RTB. HUNTRESS wants to know what's taking 31/32 so long with the tanker...(duh, weather).
2206: HUNTRESS still moaning about what's taking them so long to refuel. ARROW 31 explains it'll be another 5 minutes to get 32 onto the boom. When you can't see and are bouncing all over the sky, things like refueling go slowly «228.9»
2209: HUNTRESS sends TANKER 21 to Center on «135.525» where the tanker is told there's a new bullseye. It's being moved to MDT (Harrisburg). ARROW fighters are also setting up for the new bullseye. «228.9»
2212: HUNTRESS tells ARROW 27 flight they can RTB. «228.9» so they go over to Guard Dog on «288.35» to pick up clearances and say they're heading out on course 200 because of weather...direct Lynchburg.
2212: Meanwhile, ARROW 32 is still trying to get onto the boom and 31 is back in the CAP assuming the duty. «228.9» ARROW 31/32 to 8 AUX to find each other. «369.15»
2214: HUNTRESS tells ARROW 31 the new CAP location is Saint Thomas and ARROW wants to know where that is. «228.9»
And now that ARROW 27/28 have left the CAP, I'll end this message and continue below if necessary....
Rgr Tin those F-15's get thirsty quick! Heard one pilot mention that wind conditions causing them to use more fuel also.
This morning one ARROW asked for extra 4k fuel and tanker said he would have to deduct that amount from end of sortie.So he settled for extra 2k fuel.
Weather radar currently showing nasty weather in CAP area.They should move East
towards BWI to avoid.
JackTV
I am hearing some calls on 237.8
kinda weak but can make them out.
It is the Arrow flight.
I heard Huntress on 228.9 but now he is gone
Jack
ARROW 27 and 28 looking to rtb Eglin trying to find easiest weather path.
Don't know why Wash Ctr doesn't send them over Delmarva peninsula then
southwest to escape weather.228.900 ARROWS booming here on Eastern shore.
ARROW 27,28 departing now on 327.000 ZDC on course for Eglin.
Now hearing clear on 235.6250 ZDC.....long gone.
n3bxv
Severn, MD
<135.525> ZDC "Guard Dog" informs tanker that new Bullseye is KMDT( = Harrisburg International)
A rather confusing (and interesting to listen to) evening for the CAP... The departing Flight commenting on A2A about needing Cowboy boots and spurs due to the rough Ride...
St THomas is ST THOMAS VORTAC (THS) in PA
Lat/Long: 39-55-59.621N / 077-57-03.400W
TinEar
The new bullseye of St. Thomas is northwest of the normal bullseye...earlier said it would be to the northeast MDT at Harrisburg but that has now changed. «228.9»
Lat/longs for St. Thomas are 39.55.59 North, 077.77.03 West according to HUNTRESS «228.9»
Meanwhile, TANKER 21 has been sent to freq «363.075» where he first calls New York Center and makes contact to say he's heading to THS (St. Thomas). However, his next call is to Cleveland Center on the same freq. This is the new freq I posted last week as an unknown. Now, all we need to do is figure out whether it's really ZNY or ZOB.
Fighters and tanker are all over the place with HUNTRESS and Washington Center/Guard Dog because of the change to the game plan. Meanwhile, ARROW 27 and 28 are just chatting away non-stop on tac «369.15» as they head home to Eglin.
2235: TANKER 21 again uses «363.075» and calls Cleveland again so I guess that's who really belongs to this freq. Put it in the ZOB column.
The first time I heard this freq last week, it was a handoff from the ZDC-Hagerstown 227.125 freq. That should give a general area and now that we know it's the Sector covering St. Thomas, that should pin it down quite a bit.
2241: TANKER 21 asks ZOB if they can hold over LEONI (39-59-07.280N / 078-19-21.120W (PENNSYLVANIA) because of weather. ARROW 31 is also with Cleveland Center on this freq «363.075»
2242: TANKER 21 settles on holding around Johnstown which is in Cambria County PA. «363.075»
2244: TANKER 21 says he can fly along with the ARROW flight when they get released to go home to Eglin if they can arrange to leave together so he can refuel them on the way. ARROW flight leader is thankful «228.9». He mentions going down to around Shaw.
2259: TANKER 21 and the ARROW flight are figuring up fuel offloads and how/when they'll need to move to the south before departing and how far the tanker can accompany them. The ARROW flight is worried about how they'll get from their present location down to south of D.C. because of the weather. «228.9»
2313: The ARROW flight is about to begin another refueling operation with TANKER 21. They're working out the logistics now. «228.9»
They decide to use primary as the boom freq this time around and by 2323, ARROW 31 has finished refueling and 32 is heading for the boom. «228.9»
The ARROW flight and TANKER 21 have worked out a plan they're trying to sell to HUNTRESS....they want to start moving south at about 0430Z so they are back in the lower end of the normal CAP area around the time their replacements should arrive. They want to do this to save the fuel (and shorten the trip I assume.)
I'm going to go out on another limb with that other new Washington Center freq 235.625 and call it the Salisbury Sector. I notice that the listed freq for the VHF side of Salisbury on 128.525 is dead and I haven't heard the 257.7 freq in quite a long time. The area they are in when handed off to 235.625 is also right for the Salisbury Sector.
2359: TANKER 21 calling Cleveland Center again on «363.075»
0012: TANKER 21 and ARROW 31 let Cleveland Center know they are going to begin refueling ops. «363.075»
Although CAP primary is still 228.9, HUNTRESS must have changed his transmitting antenna location when they moved the CAP north because I haven't been able to hear him since that move.
0015: TANKER 21 lets ZOB know they are going to go back to the Guard Dog freqs in 10-15 minutes. «363.075»
0015: ARROW 31 is cleared to the boom by TANKER 21. They are again using primary 228.9 for the refueling operations.
0025: ARROW 31 flight cleared back to the Guard Dog CAP at FL 240 and TANKER 21 at FL 350. «363.075» Say goodbye Cleveland.
0030: TANKER 21 and ARROW 31 flight handed off to ZDC-Blue Ridge «285.6» ARROW 31 comes up there and tells the controller they have VHF capability but it only works 10-15 miles range (explaining why he wants to stay on UHF.)
They must have been a good way to the west of St. Thomas (THS) to be handed off to Blue Ridge rather than Hagerstown.
0032: ARROW 31 checks in with Guard Dog «288.35» and says they broke MARSA with the tanker because he's up pretty high right now. (FL 350)
0035: ARROW 31 tells HUNTRESS they are surrounded by storms and wants HUNTRESS to work out a way for them to get out of the area when it's time for them to leave. Says they can't go as fragged. «228.9»
0041: ARROW 31 tells TANKER 21 that if they leave the CAP at 0600Z, they will need a total offload of 22,000 pounds of fuel to make it home. 21 says he needs to do some figuring now but thinks that will be tight. So 31 says he can make it on 20K. 21 still thinks that will leave him short. 31 makes another offer...if they don't take enough fuel to cover a divert and just enough to make it home they can do it with 16K. The next offer is to take some from TANKER 22 when he gets here and then just 10K from TANKER 21. They then leave it up to HUNTRESS to find out when 22 will get to the CAP area. So, once again fuel is a problem. «228.9»
0044: The word is that TANKER 22 is about 40 minutes out....so the plan is that shortly before 22 gets to the area, 21 will fill up the fighters and try to leave right away for home. The fighters can get the rest from TANKER 22 and, by leaving early, 21 will have enough fuel to get home. «228.9» Hopefully, TANKER 22 will arrive with his boom in the green - otherwise everybody is in trouble.
0053: TANKER 21 asks HUNTRESS to notify him when his replacement is 15 minutes out. «228.9»
0108: TANKER 21 again asks HUNTRESS the status of his replacement. «228.9»
0110: Whatever answer he got about the replacement, he tells ARROW 31/32 to begin coming to the boom for refueling. Apparently, things aren't going to work out the way they had planned because ARROWs replacements are going to be 15 minutes late so all the fuel computations are out the window. «228.9» ARROW asks for 10K apiece but TANKER 21 says he can only manage 7K each and with that he'll be bingo and must scoot for home after giving that much fuel. ARROW 31/32 will take what they can.
0118: ARROW 31 has his 7,000 pounds. «228.9» 32 moves in for his 7K.
0119: TANKER 22 calls TANKER 21 on «260.9» and 21 tells him he should be on 228.9. They arrange their altitudes and talk about the weather.
0125: TANKER 22 Heavy checks in with Guard Dog on «135.525» to enter the area at FL 250.
0128: TANKER 21 reports ARROW 32 is off the boom and asks Guard dog for his RTB clearance and requests FL 340. Guard Dog tells him he can make a right turn and head directly for Seymour (Johnson). «135.525»
0130: ARROW 31 is given location of TANKER 22 and the tanker's Mode 3 of 3146 by Guard Dog. «288.35»
0131: Guard Dog gives TANKER 21 final clearance to head for Seymour Johnson AFB SC and clears him to FL 340. And away he goes. «135.525»
0134: Guard Dog hands off TANKER 21 to ZDC-Brooke «126.875 and 21 checks in there.
0134: ARROW 32 is going to RTB and 31 is going to stay in the CAP. They also want a change in their flight plan back to Eglin...they want to go direct to Liberty TACAN and then direct Spartansburg and from there as fragged. «288.35» So...apparently, they are going to make do with just a single plane in the CAP.
No sooner said than changed...now they are going to be released together and their replacements will be in the area in 30 minutes. Its a fuel problem of course.
0135: ZDC-Swann on «134.5» talks to REACH 322 about refueling with an ETHYL tanker and advises him to go to the tanker interplane freq 139.875 to work out the details. I can't hear either the REACH or ETHYL aircraft on this freq (or on 360.7) so Swann must be controlling other sectors and simulcasting on this freq.
Found the REACH aircraft...he's transmitting on the ZDC-Woodstown freq «125.45» and is heading for ZIZZI to hold. ZIZZI=38-56-26.460N / 074-31-44.270W (NEW JERSEY). No telling where the ETHYL tanker is transmitting. Anyway, at 0145, ZDC-Swann hands off REACH 322 Heavy to ZNY on 128.3.
0143: Guard Dog calling ARROW 31 on «288.35» and gets no reply.
0146: Guard Dog says ARROW 31/32's relief is about 12 minutes out and confirms their altitude and again confirms that 31/32 are travelling home together. «288.35»
0146: ARROW 33 turns up on «228.9» and talks with 31 about the trip home and the weather along the way. Looks like everything is going to turn out okay in spite of the fuel shortage. 31/32 say they don't need to go to the tanker again and have enough to get home.
0150: ARROW 33 is a single ship according to Guard Dog on «135.525» He's still 10 minutes out with a Mode 3 of 1072 for the benefit of TANKER 22. So they will allow a single ship to cover the CAP and are allowing 31/32 to leave together to solve their potential fuel problem if one of them had to stay over. He could take gas from TANKER 22 but that would leave someone else short later on.
0156: ARROW 33 reports he's still 60 miles south of ARMEL. He's crawling. «228.9»
0157: ARROW 33 checks in with Guard Dog on «288.35» and picks up the Mode 3 of TANKER 22 which is 3146 and is told to come in at FL 230 and go to the tanker at that altitude or above. Guard Dog also asks ARROW 31 for his request for flight level for the trip home and 31 tells him he'd like FL 280.
Continued below......
Thanks Tin for that freq,heard loud and clear here Tanker 21 call Cleveland Ctr 363.075
TinEar
0200: Guard Dog tells TANKER 22 to maintain FL 240 and is given the BRA for ARROW 33. «135.525»
0200: Guard Dog gives ARROW 33 the BRA to the tanker. «288.35» - still 25 miles away from him. 33 has him on radar.
0203: Guard Dog tells ARROW 33/TANKER 22 they are free to conduct refueling operations within the Guard Dog CAP area within FL 230 to 250. «288.35/135.525»
0205: Wouldn't you know it?....after all those fuel shortages, now TANKER 22 has too much gas and wants to get rid of some. So, after 33 refuels, 31 and 32 will go in and take 2,000 pounds apiece before leaving for home. That'll give them some breathing room in case they have to divert from their home base of Eglin. They never have explained on the air why there is a single ship covering the CAP or what happened with ARROW 34.
0213: ARROW 33 approaching the boom to refuel. «228.9» It takes a couple of tries to make connection. Various lights are out on the F-15 including the recepticle light. Tail number...
ARROW 33--EG 78-(0)513
ARROW 31 and 32 are hanging right behind and below the tanker awaiting their turns.
0223: ARROW 33 completes refueling and took 13,300 pounds. «228.9»
0223: ARROW 31 tells TANKER 22 they can take 4,000 pounds apiece which pleases 22 lots. He was afraid of having to land at home on the heavy side. «228.9» I guess they burned off the extra while waiting. Those F-15s burn around 6,000 pounds an hour - about enough to fuel your car for a year.
0233: ARROW 31 and 32 complete their refueling and wind up taking 5500 pounds apiece. «228.9»
0234: ARROW 31 and 32 are cleared off the CAP by HUNTRESS and finally begin their trip home. «228.9» They go over to Guard Dog on «288.35» to get their clearance and change the flight plan...now it's direct Richmond, direct Eglin. They are climbing to FL 280 for the flight.
0239: Guard Dog, while on «288.35» hands off ARROW 31 and 32 to ZDC-Brooke on «126.87(5)» but they ask for UHF and get «327.0» where they go to check in in a non-standard formation two-mile trail so pick up a separate squawk for 32. They also go to 8 AUX on «369.15» to chat about how great TANKER 21 was for trying to help them and how uncomfortable they were during the thunderstorm. Read: worried. Anyway, they're gone and now I'm gone.
CAP primary and boom freqs are now together on 228.9 and Guard Dog is working 288.35/135.525.
Good night/morning all.
ScanManQSL
QTH: Montgomery County, MD / Washington, DC
I just turned on my radio few mins ago....Good Morning Everyone
The Players: Tanker 24, Areo 22 and Areo xx???
08:56: I have Tanker 24 calling Andrew command post on 378.1. Called Twice
and no one answers him.
08:57: Tanker 24 calls on 228.9 for a radio check.
09:02: ARROW xx? asks where are the replacements ?
09:05: Tanker 24 gets a hold of Andrew command post. He asked for the current weather observation. Standing By Bango weather?
09:06: 228.9 Tanker 24 tells ARROW XX? he is looking for the weather at his home plate.
09:10: 228.9 ARROW 22 is going to top off with the tanker. He asks for 6k of fuel. ARROW xx? Ask what the status is for the other fighters.
I had stepped out of the house for a few hours. My radios are back on again.
12:30: I have Tanker 26 up flying. 369.15 Air2Air I have ARROW 23 saying thunder clouds are building.
12:31: I have Tanker 25 on GaurdDog 135.525. He is heading back home and switched to Montebello 121.67
12:33: Tanker 26 is talking to GD 135.525 that he will go down to FL24.0
13:02: It&#8217;s been quiet for the last half hour. Just a small chit-chat just now. ARROW 23 is saying he is bulls eye @ xxxxxxx?. He is saying he is cold and ARROW 24 is tracking above the cloud.
13:27: Tanker 26 and ARROW 23 are on 320.6 Boom Freq. . .
I am going to step out again. I will continue later on.
n3bxv
Severn, MD
1745 Turned on the Radios and Heard Arrow 25 Flight with Huntress<228.9> and Guard Dog<288.35> getting Clearance to RTB, then switced to "8 AUX" and come up on A2A <369.15> with an "Ops Check" Later Cleared to KVPS (Eglin), and Pushed to <284.7> , but never heard them on that freq
TinEar
Turned the radios on here at 1900 and am hearing another move of the primary CAP freq to «260.9» with a boom freq of «320.6». Currently, the F-15s are ARROW 27 and 28 from the 60th Fighter Squadron, 33rd Fighter Wing, Eglin AFB FL. The tanker is TANKER 28, a KC-135R from McConnell AFB in Wichita KS. ARROW 27 just finished his refueling op and 28 is approaching the boom now for his topoff.
We're under a severe thunderstorm watch until 10 p.m. for an area that includes the CAP track. Hopefully, those F-15 and tanker pilots won't have to dodge around the weather as they did last night. It's interesting listening but poses somewhat of a danger to the guys up there doing their job.
ScanManQSL
NWS just updated their forecast for tonight. Looks like we dodged the bad weather. Tonight for the WashDC Metro Area is Partly cloudy, with a low near 50's.
22:00: ((135.525)) Arrow 27 is heading back home. He is handed off to the ((128.47)) controller. That is the last of him.
22:16: It&#8217;s been pretty much quiet for the last hour. Until now, ((260.9)) Arrow 29 says he needs some gas. He is 12 miles away from the tanker
23:19: Arrow 31 is cleared to top off with Tanker 29
23:31: ((260.9)) Huntress says to Arrow 31 are you from the so and so unit? Arrow 31 says yes he is. Huntress says make sure you say hi to JB.
23:38: Arrow32 is cleared to disconnect with the tanker. I must of missed Arrow 32 asking for a topoff.
23:39: Arrow 31 & 32 are both cleared from the tanker.
23:49: ((260.9)) Tanker 29 is calling Huntress. He is asking for the weather at his home plate. He says he has 30minutes left until Tanker 30 takes his place. I was unable to pick up Tanker 30 but he is on his way.
00:50: Tanker 29 ask if Arrow 31 wants to top off his tanks before his goes home.
00:52: Huntress gives Tanker 29 the current WX conditions.
It is now 00:56 and about to get some badly needed ZzZzZz's. Good Night everyone
TinEar
0050: Just checked to see if the CAP is still awake and heard TANKER 29 making contact with TANKER 30 who is on his way toward the area on «260.9». TANKER 29 asks ARROW 31 if his flight needs gas since 29 will be leaving in about 30 minutes. ARROW 31 says he'll go the tanker in about 15 minutes.
0108: ARROW 31 trying to refuel from TANKER 29 but is having trouble connecting to the boom. They are using primary «260.9» as the boom freq also.
0113: ARROW 31 finally makes a connection with the boom. TANKER 29 says the last time 31 disconnected he really dragged him around so they're going to try timing the disconnect so they do it together. At 0116, ARROW finishes taking about 13,000 pounds. «260.9» ARROW 32 is coming in for a topoff now.
0118: ARROW 31 asks HUNTRESS for the weather at Eglin two hours from now and wants him to call Eglin to see if ARROW 33 got off the deck on time. «260.9»
0119: TANKER 30 checks in with TANKER 29 on «260.9» to check for entrance altitude and then with HUNTRESS to check in.
0121: TANKER 29 tells HUNTRESS he'll be ready to RTB in three minutes. «260.9» (when he finishes the refueling op with ARROW 32.)
0124: TANKER 29 reports bingo and requests RTB. «260.9» About a minute later ARROW 32 disconnects from the boom after taking 11,700 pounds of fuel.
0127: TANKER 29 contacts Guard Dog on «135.525» to pick up his clearance home. Guard Dog tells him to maintain FL 240 and clears him home to Seymour Johnson. TANKER 30 then comes on the freq to get clearance into the Guard Dog CAP.
0128: Guard Dog hands off TANKER 29 to ZDC-Brooke «126.875» and 29 checks in there at FL 240. (Heard him again weakly on the same freq at 0142...long time with Brooke.)
0137: TANKER 30 wants to know if 29 filled up the current fighter pair and if the ARROW 31 flight will be coming to him for fuel. The answer is that 29 did and that the 31 flight will not come to him for fuel. «260.9»
0138: The ARROW 33 flight is coming into the area chatting on tac «369.15». In chat, they mention they couldn't make contact with Washington Center on «307.025» There's that freq again. They also mention the 288.35 Guard Dog freq isn't answering them. The 33 flight then checks in on «260.9» and talks to 31 about the comm problems. 31 agrees they haven't heard anything on 288.35 in a while.
0143: ARROW 33 does make contact with Guard Dog on «288.35». Guard Dog finds out it's a two ship F-15 flight so assigns a separate squawk for the wingman which 33 takes exception to so GK has to explain it to him that he needs to specifically identify the aircraft before allowing them to enter the CAP area. ARROW 33 also adds that they couldn't make contact on 270.35 either (ZDC-Shenandoah).
0145: Guard Dog clears the ARROW 33/34 flight to enter the CAP and gives them altitude block 21-25,000 and hands them off to HUNTRESS. «288.35»
0147: ARROW 31 advises Guard Dog they'll need their clearance home in a few minutes. «288.35» Guard Dog tells him to work his way toward the southern end of the CAP before getting ready to leave.
0153: The new ARROW flight is going to TANKER 30 to replenish their fuel load after the long flight from Eglin. «260.9»
0200: ARROW 33 finished refueling and 34 is going to the boom. Both flights complained about various lights on the tanker they wanted turned down. Meanwhile, ARROW 31 requests to RTB to HUNTRESS. «260.9» HUNTRESS approves and off they go to Guard Dog on «288.35» where Guard Dog clears them from the CAP to Spartansburg and then to Eglin at FL 240 for now and 280 later.
0202: ARROW 34 cleared onto the boom. «260.9» and makes contact at 0204....breaks contact and tries again a couple of minutes later.
0204: ARROW 31/32 go to Man AUX to chat...that's not 369.15 and I can't find them. «260.9»
0205: Guard Dog clears ARROW 31 flight to climb to FL 280. «288.35»
0207: ARROW 33/34 along with TANKER 30 decide they will use «320.6» as a boom freq and change over to that freq.
0208: Guard Dog hands off the ARROW 31 flight to ZDC-Montebello «284.7» where they check in.
TANKER 30 should be here until about 0500 and ARROW 33/34 until about 0600 and that's my cue to crash and burn. Later...
This morning the only CAP activity heard was SPIDER 41 going to Tanker 31 on 260.900.
Also had a Tanker 32 trying to call Huntress on 324.000 no joy.
ScanManQSL
I have Gasket 65 & 66 flying today.
09:50: Gasket 65 is going to refuel with Tanker 32.
10:03: Gasket 65 just got off of the tanker. He received 6.6k of fuel. He is leveling @ FL23.0
10:04: Huntress tells Spider 41 to work the south end of the CAP.
EDIT: I just got back home...What is the status of the CAP? I know they are going to be rapping it up soon.
n3bxv
Severn, MD
Based on information from the NorthEastMilAir List, the Gasket Flight is out of the 107 FS / 127 FW, Selfridge ANGB, Michigan...
I haven't heard them for a while, did they RTB?
