Sticky Thread for MilAir
freqhopping
A Customs Blackhawk just flew north out of Leesburg. It think it may have just departed Leesburg airport.
At 1143 a female voice reported that OMAHA-3 had a 10 ETA for wherever they're going.
TinEar
Glen Burnie, Maryland
Turned on the scanner briefly and heard a couple of unusual aircraft....
The first was ATOKA 07 calling HUNTRESS on «364.2» for the usual modes and codes checks. ATOKA (which he spelled phonetically) is a C-130 from the 352nd SOG, RAF Mildenhall, UK. That was 1406-08.
Then there was an OPEN SKIES 12T with SAM Command on «378.1» starting at 1400. He called and called with the usual results before finally switching to «141.55» at 1410. At that point he was 20 minutes out expecting to arrive at 1830Z (only 4 hours between local and Zulu time as of today). Said he had 28 SOB, requested the runway barrier be taken down, airstairs, power cart and 25,000 pounds of fuel. He also requested Customs and that the International Treaty Compliance Officer be notified of their arrival. He also asked for a crew bus. His tail number is 61-2670 which makes him an OC-135W. Finally, at 1430 he was given parking in 11 Row and said he was still 5 minutes out.
freqhopping
Lots of inbound transports tonight. The latest are:
2030 REACH-122T inbound to Andews, A1, 29 pax, 5 vehicles
2110 REACH-01 inbound to Andrews, tail #84140, C-21 for a quick turn around, has A5, A3 +1 onboard
2122 REACH-134Tinbound to Andrews, a C-130 with 2 vehicles, 2 min out, A1, no fuel needed
2124 REACH-3119 inbound to Dover A1, 30 min ETA, needs fuel, will be uploading 11 pallets for Iraq
Someone else was on 344.6 getting the weather conditions for Andrews and also wanted to know the NCAA score. Get your sports and weather together on 344.6 AM. :)
At this time there is a real nasty line of storms stretching down the Chesapeake Bay.
DPD1
I didn't check if you guys already mentioned it... But the Navy Global Hawk was delivered from Edwards to Pax, back on the evening of the 27th I believe. They often use the call Hitest out here, but I don't know what they will use there. It will most likely stay within whatever complex those guys usually fly in there, since it's a big deal to fly it out in normal ATC. They can in fact talk through the aircraft itself... It has a very dry sound, since it's obviously a guy sitting in a building or trailer on the ground. In fact, sometimes the audio has a weird echo, which I assume is due to monitoring speakers in the same room.
Dave
http://www.dpdproductions.com
- Custom Scanner, MURS, GMRS, & Ham Antennas -
TinEar
CAP is active early in the 1200 hour on HUNTRESS primary freq «228.9» It is manned by F-16s from the North Dakota ANG, deployed to Langley. Callsigns are SPIDER 45/46 for the fighters and they are supported by a TANKER 04 from Pease in NH. Fighter tac is «138.025». Earlier, the TANKER 04 KC-135 was heard on Andrews Metro freq «344.6» asking about weather at 1800Z for PSM (Pease NH) and 1830Z for KBGR (Bangor ME) and KGTB (Ft. Drum NY).
1305: This is an almost silent CAP. In the past 45 minutes there have been two transmissions on 228.9 - both with the tanker - and two on tac between the fighters
Arriving at Andrews at 1243 were two F-16s from the ND-ANG using callsign NODAK 1. They used Reagan TRACON freqs «343.7» with difficulty and then «322.3» before switching to Tower on «349.0» to land.
At 1249, TRAP 71 (F-15 Langley) flight with Norfolk TRACON «370.925» and then over to Giant Killer on «249.8» to work for the next 30 minutes with a LIMEY flight (also F-15s from Langley). A few minutes later, TRAP 73 is asking GK about a P-3 in the area. Ops freq in GK's area is «373.1» TRAP 71 is a flight of at least five aircraft.
BANDSAW (E3C from Tinker AFB OK) is controlling the fighters today. He's also working with GK on «249.8»
1309: Bollen Range active with a single aircraft «237.2» scouting out the range for two more aircraft to follow. Heard someone a bit earlier on the Philadelphia Approach freqs so it's probably A-10s out of Willow Grove. At 1315, the aircraft at the range mentions waiting for UGLYs to get there which confirms Willow Grove A-10s.
1316: TANKER 04 calling "Any Metro on 344.6"
1317: HUNTRESS tells TANKER 04 to coordinate his clearance to RTB at 1730Z and then gives 04 the weather for Pease. «228.9»
1319: HUNTRESS tells SPIDER 45 to coordinate clearance to RTB «228.9»
1319: TANKER 04 with GUARD DOG on «135.525» for clearance back to Pease and mentions it'll be in another 10 minutes when he clears out.
HUNTRESS is so loud and clear that again he sounds like he might be transmitting from an antenna at BWI. He's every bit as loud or louder than the aircraft.
1325: SPIDER 45 to GUARD DOG on «135.525» to announce 5 minutes to RTB time. Wants direct Langley at FL 210.
1329: HUNTRESS clears TANKER 04 to RTB. «228.9» 04 switches to 135.525 to pick up clearance and says he's heading for EMI (Westminster VOR)
1329: HUNTRESS clears SPIDER 45 flight to RTB. «228.9» SPIDER 45 reports low fuel and both Code 1. 45 then tells 46 to switch to V-19 on 288.35 and they do to pick up their clearance back to Langley. They are now also on tac 138.0. (He said "Victor 19" but he obviously meant Uniform 19 for 288.35.)
1335: SPIDER 45 flight with ZDC-Calvert «281.4» on their way home.
1335: Fighter tac freqs «138.15» and «138.55» active. Unknowns.
1340: SPIDER flight beginning descent to 14,000 feet «281.4»
1342: TANKER 04 calling Andrews Metro «344.6» He spells his callsign phonetically - twice. He wants wx for 1830-1930Z for primary PSM (Pease), alternates BGR (Bangor), CEF (Westover), GTB (Ft.Drum). At this point he's becoming weak as he flies out of the area. He receives the wx for each airport over the next six minutes.
1345: Fighter tac freq «141.575» active. Unknown.
1346: RABID 71 flight (F-15 Langley) into GK's area «249.8»
1346: SPIDER flight with Norfolk TRACON «370.925» and then it's "Push 11."
1349: RIDER 81, flight of two, (F-15 Langley) to GK on «238.1» with no joy so over to «249.8» to enter the area. Confirms they'll be working with RABID flight. Change to 16 and come up on ops freq «389.1»
1352: Customs aircraft OMAHA 1 active on «282.425»
1400: RIDER aircraft in air combat maneuvers on «389.1» are mentioning targets between 52,000 and 61,000 feet. Not sure who/what they're going after but it's certainly a high flying son-of-a-gun.
1406: Tanker interplane «365.7» active...couple of aircraft chatting about broken things on the aircraft. I next hear the same aircraft with Dover CP on «349.4» talking about the boom not retracting. No callsign yet.
1407: Refueling freq «320.6» active with RABID F-15s. This is the freq I most often hear Langley fighters using for refueling.
1410: REACH 3894 going into Dover IDs as a C-130. Twenty minutes out and A-1...needs 25K fuel. «349.4»
1410: Also have REACH 6002 into Dover on «349.4»
1413: Warren Grove Range active «283.1»
1430: Fighter tac freq «138.75» active. Unknown.
1434: REACH 337 with Andrews Approach on «119.3» I mention this only because he called multiple times on «378.1» beginning at 1412 and called all the way until he was ready to enter the pattern and never did get heard on the Command Post freq.
1434-39: BANDSAW LIMA calling someone (not HUNTRESS) on «364.2» Called twice, both times ground callsign blocked.
1443: Langley tac «233.525» active.
1445: Warren Grove Range still active «283.1» and it is the same aircraft on tac «138.75» Probably PA-ANG A-10s from Willow Grove.
1452: Finally caught that callsign BANDSAW LIMA is calling on AICC «364.2». It's OKIE SAM at Tyndall AFB FL. Callsign is associated with AWACS but I'm not sure what that association is. He had contact for a few seconds and then began calling again.
Jack, you know, right?
1457: RATS 21 flight (F-15 Langley) into GK's area on «249.8»
1459: BANDSAW LIMA in contact with someone else - not OKIE SAM - and says that he's heading home. «364.2»
1500: BANDSAW LIMA mentions to someone that he's in the NEADS area but is not sure where the dividing line is (I guess he's talking about the point where he'll leave that area.)
1503: LIFTER 31 (C-17, 437TH AMW, Charleston AFB SC) arriving McGuire on CP freq «319.4» 30 minutes out.
1505: Have what I believe is KANSAS 01 with Reagan TRACON on «270.275» and then with Andrews Tower on «349.0» as he landed. If I heard that callsign correctly, it's a B-1B bomber of the 127th BS from McConnell AFB KS. Wish I was positive of that...I'd take a quick run down to Andrews to take a look at it. I've seen them in the air but never up close and personal.
1520: Martin State A-10s active on tac «142.3» It's a flight of four. Callsign RAVEN.
1527: RAVEN flight of A-10s is in BayWatch area on «270.8» asking for a discrete freq if able.
1530: RAVEN flight working with a FAC at the Pax Range - callsign BROKEBACK. «142.3» (So who picked that callword?)
1534: RAVENs changing to discrete freq «264.55» and call RAINCHECK. They are giving coordinates for a simulated SA-6 missile site they must attack. They also call BALLPARK a few minutes later and continue their chat on tac «142.3» while setting up for their attacks on the discrete freq. BROKEBACK seems to be the primary FAC at the range.
1600: Quitting time...END OF LOG
dparana
Hey All,
A little continuing action from the A-10s that were working Bollen Range:
1350: Caught Madhog 1 contacting Cleveland Center on 353.85 with request to enter the Duke MOA and if a tanker is enroute. Advises that he will be headed back th NXX (Willow Grove) when done in the MOA.
1356: Madhog 1 contacts Sluff 62 (OH ANG - Rickenbacker AFB) as he gets clearance into the Duke <<301.60>>
1403: Madhog 1 hooks up, boom interphone weak and unreadable. <<301.60>>
1404: Mahog 1 requests that he heads back towards Slate Run and comes in for another hook-up. Sounds like he's killing a little time. The two are working on their second rendezvous. <<301.60>>
1407: Ugly 1 comes up on 338.30 they want to switch to 353.85 "Push 18" but they both still come up on 338.30. Ugly 1 mentions that their system shows 353.85. So they switch to 353.85 manually and contact Cleveland Center.
1411: Ugly 1 contacts Sluff 62 on 301.60. Sluff 62 advises that they have Madhog 1 in tow.
1414: Madhog 1 is done and is headed back to Willow Grove.
1416: Madhog 1 contacts Cleveland Ctr on 353.85 and is going direct Willow Grove at 15,000.
1417: Uglies request 1,000 Lbs a piece to Sluff 62 <<301.60>>. (They will probably burn that much flying to and from the Duke, seems like kind of a waste, but the boys need training).
1418: Ugly 1 actually got about 1,300 Lbs.
1419: Ugly 2 bellies up to the bar for a drink.
1420: Uglies are wrapped up and say their goodbyes to Sluff 62 <<301.60>>.
1422: Uglies contact Cleveland Center on 353.85 and head back to Willow Grove at 15,000.
1423: Uglies "Push 17" and pop up on 338.30 (NY Center).
And that's all folks. A typical (and Professional) Duke gas and go.
Dave
freqhopping
A few minutes ago I heard "601" with Snow Hill 256.8. He mentioned BRISS, Madison, Barnes and picking up the Jet121 route.
1637- HOVER-31 with Snow Hill on 256.8 Also RATS-21 who then switched to Giantkiller on 249.8
1640- HOVER-31 checked in with Giantkiller on 249.8 and will be working with RATS
TinEar
Travis, do you think that 601 could have been something like FIST 01. Of course, that doesn't fit for anything at Barnes which was his destination. I also heard him come up on that 256.8 ZDC-Cape Charles freq, then to 281.45 with ZDC-Sea Isle and finally to 353.5 ZNY-Manta. I also thought it was 601 at first but, the more I heard him, the more I thought it was a callsign in front of the 01. I'm just not sure. It was a flight of two aircraft.
Around 1830, there were a couple of aircraft on refueling freqs 238.9 (primary), then to 319.7 (secondary) and also tanker interplane 143.825. One of them was OPEC 28 (KC-10A McGuire) and I never could catch the callsign for the other one. Its suffix was 19.
1928: Have a pair of fighters on tac freq «143.1» which is new to me. Said they were airborne at 22 after the hour. Sounds like they may be A-10s from Martin State but no callsigns used yet to prove it.
Edit: Almost certain now of the ID as Martin State for this flight. Terminology IDs them as A-10s. They work for the next hour or so doing ground attack exercises at Pax. They turn out to be RAVENs...see below.
Also have a BATON 54 (EC-130, 193rd SOG, PA-ANG Harrisburg) with Giant Killer on «255.0» which should put him up around the W-105/107 areas.
1941: Have another pair of A-10s reporting off the deck from Martin State at 1940 on tac «142.3» Turns out to be COLTs.
1950: CRAB 56 (C-130J Martin State) landing at MTN with Tower on «121.3»
2025: The fighters from 143.1, callsigns RAVEN 1 & 2, are reporting in to Raven Ops on «347.2»
2032: RAVEN 1 & 2 landing at MTN with Tower on «297.2»
2039: BATON 54 to Giant Killer on «255.0» to report he's 33 miles from leaving W-107 and is going direct KMDT (Harrisburg) at FL 180 via Sea Isle.
2044: BATON 54 handed off to ZDC-Sea Isle «133.125» where he's told to climb to 19,000 and he reports he's RTB.
2045: A commercial Delta aircraft (flight 1984) asks Washington Center what kind of aircraft BATON 54 is and 54 responds directly that he's an EC-130J. (Most callsign lists don't show the J, mine included, so I'm adding it.) «133.125»
2047: The A-10s from tac 142.3 are now landing at MTN with Tower on «297.2». Callsign is COLT. They also report in on «347.2» that they are both Code 1.
freqhopping
I don't know. He was really clear on 256.8 but I never heard him after that. I only heard him a couple times.
At about 2040 I heard GERMAN AIRFORCE-901 (Heavy) departing IAD on 125.05. Then he switched to BWI approach on 128.7. I had a visual on the plane at about 10,000ft just before they turned to the east. It was too dark to ID the plane but it didn't seem any different than commercial planes.
n3bxv
Severn, MD
It was probably one of the Airbus A310s that the Luftwaffe operates back on forth to Dulles...
http://www.airliners.net/open.file/0084757/L/
TinEar
Air Force 1 lands back at Andrews with Approach on 119.3 and then with Tower on 118.4. Gear down at 1325. The President went to New Haven CT this morning. While there, a CAP was in place. Participants were COSMIC 45 and 46, F-16s from the NJ-ANG, along with refueling support from TANKER 04 and 05, working with HUNTRESS on 260.9. COSMIC tac was 138.875. Aircraft supporting AF1 were SAM 93 and 94 again with comms on 136.725.
Also had a SAM 0046 from 1258 to 1309 working with RENEGADE on 139.15. Kind of unusual since that's a DC-ANG tac freq. He mentioned he was 50 miles out from Andrews and looking for maximum range on the sparkle. All his comms were about the sparkle. He then went back to Andrews by 1313 on freq 119.3 where he was made to circle and wait to land because of the ramp freeze in effect at that time.
Other than those two flights, there has been nothing of significance today. A few TEAM (21/22/32) KC-10A tankers from McGuire have been flying around. They've made several contacts with McGuire Metro on 239.8. Even transport activity into the three AF bases has been very light today.
1336: GAUCHO flight (F-15 Langley) on Norfolk TRACON freq 370.925. Push 11 Prime and off they go.
1341: GAUCHO 71 flight into Giant Killer's area on «249.8» where he reports as a flight of two and will be working in the area for the next 30 minutes with a YODA (F-15 Langley) flight. Ops freq is 292.3.
1357: RIDER 74 (F-15 Langley) reports to GK that he's a flight of two (74 and 72) RTB to Langley...28 miles east of the field descending from 32,000 feet. «249.8»
1403: RIDER 71 to GK reports as a flight of three...30 miles east of HEELS, RTB. «249.8»
Back later....
TinEar
F-16 from Shaw crashed this evening. Pilot ejected into the water off the coast from Myrtle Beach and was rescued a couple of hours later. Crash was shortly before 6 this evening. That's the second F-16 crash in a week. The other was in Utah a few days ago.
TinEar
1820: HARCAR 01, flight of two aircraft - probably fighters, approaching Andrews with Reagan TRACON on «270.275».
1825: HARCAR 01 switches to Andrews Tower on «349.0» and both aircraft land on runway 19L.
NOTE: HARCAR is not a callsign that computes in any of my databases. However, it was spoken very clearly several times. HARCAR is urban slang for an exceptionally hot chick...one that causes RHS (Really Horny Syndrome).
md_p97
Barnesville, Maryland 20838
Hello All,
I didn't see a NOTAM mentioned, so I thought I would chime in. According to the Fredeick Post, due to increased security, Catoctin Mountain Park will be closed starting at 7:30 tomorrow (saturday) morning through Sunday evening. So listen up for the CAP flights.
regards,
Paul
Vschlitz
Not much activity up here. No air activity at all. Must be someone else other then the Pres. up on the mountain.
JackTV
Hey All,
I heard a flight out of Andrews (F-16's) he was on 143.15
but it sounded like he was talking to someone I could not hear....
perhaps ops or someone like that. It did not seem like A/A chit chat.
So that was kinda weird. Also he mentioned a freq I never heard before
290.425 I caught something like a 100 miles out.I am pretty sure this was a flight of
2 but I never heard the other jet. Maybe a new A/A ferq we do not know about ??
Jack
Dank
MD
I can confirm visually what you heard. I was just south of Andrews yesterday morning and saw the flight of 5 arrive from the south. A group of 4 wing tip to wing tip with the 5th plane close behind in the center. A few seconds later I saw 3 of them circle back around before landing. I'm guessing 2 of the first 4 landed, one on the left and 1 on the right. Followed by the next 3. Wish I had my scanner to listen to the approach.
TinEar
Stuff heard today...
Refueling:
1250: 277.0 Pax River freq...120 refueling from 815. The 120 was probably a Salty Dog.
1252: 252.8 with U/I aircraft.
1253: HOSER 12 (KC-135 McGuire AFB) with ZDC-Norfolk 133.825 and then ZDC-Cofield 123.85.
1320: DC 91 (KC-135 Andrews) with LIBERATOR on 351.2, 20 minutes out with 5 Space A pax to drop off.
1333: U/I McGuire tankers on interplane 143.825.
Arlington National Cemetery Memorial Flyby:
1309: DRAGO 51 two-ship flyby working the normal Andews freq 279.575 for this type activity and tac 139.7. They finally descended and did the actual flyby at 1353. Soon after takeoff, they also used the Andrews Approach 335.5 freq. They're still flying around the area on 139.7 at 1407 and getting ready to head for Andrews. At 1409, they switch to button U-5 and come up on Approach 335.5. In chat, one of the pilots says, "I hope all two people enjoyed that," in reference to an apparent small crowd at the cemetery. At 1410 they go to Tower freq 349.0 to land.
Added: Forgot to mention they also made contact with DRAGO 2 - the usual photographer - during the flyby. I believe DRAGO 2 is ground based at Arlington.
Also heard a YANKEE 75 (KC-130 VMGR-452 Stewart ANGB NY) with Navy Ops at Andrews on 386.8 at 1227 calling a couple of times.
1612: Flight of F-22As up from Langley on tac 228.45.
freqhopping
There's a whole slew of MUSSELL flights in the air all over the place right now. I've heard -1, -06, -07, I thought -15. MUSSELL-1 flight of two is just now leaving Mt. Weather. They contacted approach on 120.45 and advised they'd would be heading towards Leesburg, then to Potomac and DCA. Then they switched over to 125.8 for clearance.
I saw MUSSELL-1 solo heading out there about 30 minutes ago. They were having problems contacting Bluegrass Ops.
1605- Cleared Leesburg.
