DPD1 said:
A lot of these can be traced by the number using FN. N53FN. Most of theirs are leased from L-3 comm.
Dave
Well, I'll be.... Thanks Dave. The 53 gets a return but the 08 doesn't. It has been a very long time since I heard the INVADER JACK before today.
The BULLY pair on «143.6» still going as of 1957 in air combat maneuvering simulated with HUNTRESS. Over to SOF «139.9» at 2006 where they report both are Code 1 and 10 minutes out from Andrews. At 2017, they're with Reagan TRACON on «270.275» approaching the field. Next stop «349.0» with Andrews Tower.
Listening to that test activity on «345.1». It almost sounds like the Northrup-Grumman test flights. 537 reports RTB at 2004 and says the debrief will be at 2100.
Travis, the 254.1 signal is being received here full meter strength. I have no idea what it is.
1959: Air refueling freq «252.8» is active...no callsigns heard yet. At 2009, one of the aircraft here reports he's going direct Syracuse. They're in altitude block 26-27,000. The two aircraft are using suffix 11 and 12.
2020: Langley SOF «383.2» active. A couple of minutes earlier I heard a flight leaving the GK area on «249.8». No callsign heard.
2027: Langley's Iron Ops on «357.1» active with HOOPER flight.
2028: Giant Killer's ops freq «391.2» active.
2038: VAPOR 81 flight (1st FW Langley) with Giant Killer on «249.8»
2041: COBRA 50 (EA-6B, VAQ-209 Andrews) landing at Andrews with Tower on «349.0»
2031: REACH 103T calling SAM Command at Andrews on «141.55»
Remember the 378.1 freq is closed to traffic until late tomorrow per NOTAM. Hopefully, they'll have the problems solved when they bring it back up. They installed a new transmitter on that freq a few days ago that brought the problem from bad to worse. We logged TRACK 01 from Flight Standards giving it a test and flunking it. After that, they issued the NOTAM and took it off the air.
2043: Giant Killer's ops freq «292.3» active.
2047: ROACH 71 flight (1st FW Langley) with GK on «249.8» This flight using tac «228.175» Flight of four.
2056: ROACH flight on GK's ops freq «312.3»
And that's the end of me for tonight...time to watch The Unit and then The Shield.
