klausserthib
- Joined
- Jan 27, 2019
- Messages
- 8
- Reaction score
- 0
That virus report is for an archive called 'TTT_1.7.1.0_release.rar'.Windows and Virustotal reports me a trojan in the last release (1.7.1.0) but no in 1.7.0.0.
Check that the recording plugin in SDR# are set to audio and you probably have to untick the baseband box.Then I recorded an IQ file of a tetra signal with calls in it, in order to do the testing. I then open the file in SDR# and play it. If the recording of TTT is enabled, in the moment of a call, it will hang, the plugin is not affected. If the recording option of TTT is disabled, it will not hang on a call.
/Ubbe
I don't think this is a bug but rather a system specific issue.I'm reporting a bug:
Version: 1.7.1.0
Both the plugin and TTT work well except if I enable the "Record all calls" in TTT. If it is enabled, TTT will freeze everytime a call is received.
How I tested this:
I realized this happened. Then I recorded an IQ file of a tetra signal with calls in it, in order to do the testing. I then open the file in SDR# and play it. If the recording of TTT is enabled, in the moment of a call, it will hang, the plugin is not affected. If the recording option of TTT is disabled, it will not hang on a call.
Information about my setup:
Latest SDR#, Windows 10. Default audio output of SDR# is Virtual Cable, and I have activated the "listen to this device" on Windows.
TTT has the option to output a 'Now Playing' file (plain text) with a delay to help synchronize the metadata to audio.Thanks for the reply. Actually the sound is not the biggest issue here, but good to know about your solution. I might very well run into the same issue here.
Biggest challange for me is to have the display showing. The remote menu over VNC viewer could be a solution, but I'd prefer to have the data show in my POC-radio's display (running on Android OS), using the radio's fonts. I think that way it will work better with screen saver, sleep mode,notices, etc. I have very limited experience from Android before so there might be an obvious solution already in place, that I have no clue of![]()
If you want audio + network info just try run tetra handheld using receive only FW
Does your streaming program accept metadata from file?
Is TSSDR or TTT or AOR DV1 and DV10 registered on the network to receive or show/use traffic information?Erik211 said:I don't know of any FW/terminal that can actually listen and follow TETRA traffic without being registered on the network?
I don't know what this zello is. Or what it does or your requirements to stream to a remote device.Yes, thank you - this would be most useful! I do not know of any way to get this into Zello however (OR could it be a feature hidden far deep in Zello work perhaps?). But actually the audio and the text can be two separate apps. So basically I then need an application which can read the "now playing" text file, and present it as text in an Android app.... Any tips?
You were speaking of a TETRA handheld with receive only firmware. As Ubbe wrote every TETRA terminal needs to register on the network.Is TSSDR or TTT or AOR DV1 and DV10 registered on the network to receive or show/use traffic information?
