SDR# TETRA Demodulator Trunk Tracking Demonstration
Erik211
Stockholm, Sweden
I am looking for sounds of Motorola MTP850 and the likes to use with TTT (i.e. replace the standard call setup, release, priority, etc in the snd-folder). I know there are some recording on Youtube, but I haven't found anyone without too much background noise.
If someone has files ready, or know the tone frequencies / lengths it would make my day :)
L1274
Hi everyone. I have a question. I use 1 usb dongle and a single mode of TTT. I accept channel 1001 (Main:1001 Current:1001) and channel 1009 (Main:1001 Current:1009). TTT is located on channel 1001. How do I make TTT jump from 1001 to 1009 if the call is 1009???
Ubbe
Stockholm, Sweden
That's what TTT are used for, it does it for you, trunk tracking the call. If you do not use trunk tracking you only have to use the russian tetra plugin.
/Ubbe
L1274
If a call to 1009 SDRSharp + TTT does NOT automatically switch to channel 1009. How can I fix this?
Ubbe
Stockholm, Sweden
The best way to start would be to read the documentation and ensure that you have followed it. It has to be something you have missed.
/Ubbe
L1274
I use a translator. It is very difficult for me to understand what is written in the instructions.
frankfcm
Hi all.
I'm trying to install last version ( 1.7.1.0 ) but windows block it by Trojan:Win32/Azden.B!cl.
Have you notice that? Any version clean or other links avaliabe?
Thanks,
thewraith2008
You are using the TETRA Demodulator plug-in + TTT in single mode, How are you determining that there is a call on carrier: 1009?
Does this show up in the 'Network Info' window on the Calls tab?
What kind of call is it? Group/Private. Do you have any logs of the call setups?
Does TTT follow other calls? (on carrier 1001)
It's possible that the activity on 1009 is not for a call that was setup on the current LA. TTT does not work with this kind of scenario.
It's possible that the call is encrypted in which case there will not be any call following.
Latest version (v1.7.1.0) can be found here: Release post
L1274
Yes. I use 1 USB dongle + TTT in single mode.
Yes. Displays activity on the Main channel + Other channels belonging to the main channel.
Yes. I still have the logs.
TTТ displays all 1001M + 1009 activity. Sharp is located at 1001M and plays 1001M calls. BUT DOES not JUMP to 1009 when calling there.
I do not understand
Mostly open calls
I will record a video soon.
