You are using the TETRA Demodulator plug-in + TTT in single mode, How are you determining that there is a call on carrier: 1009?
Yes. I use 1 USB dongle + TTT in single mode.
Does this show up in the 'Network Info' window on the Calls tab?
Yes. Displays activity on the Main channel + Other channels belonging to the main channel.
What kind of call is it? Group/Private. Do you have any logs of the call setups?
Yes. I still have the logs.
Does TTT follow other calls? (on carrier 1001)
TTТ displays all 1001M + 1009 activity. Sharp is located at 1001M and plays 1001M calls. BUT DOES not JUMP to 1009 when calling there.
It's possible that the activity on 1009 is not for a call that was setup on the current LA. TTT does not work with this kind of scenario.
I do not understand
It's possible that the call is encrypted in which case there will not be any call following.
Mostly open calls
I will record a video soon.
I do not understand
Mostly open calls
