DEC | HEX | Mode | Alpha Tag | Description | Tag |
5155 | 1423 | DE | USM Dist 1 | District of New Jersey 1 | Federal |
5157 | 1425 | DE | USM Dist 2 | District of New Jersey 2 | Federal |
Unlikely. One of the primary reasons for the buildout of the 4F0 system is to provide wide area coverage in the region so that they no longer have to pay fees for use of the NJICS.Since the US Marshalls have these two talkgroups below on the NJICS system, I wonder if we will see a simulcast as they transition over to this new federal system.
Those are both Site 127 control channels. Can you program the system with those channels in one site and verify that it's 127? Maybe see if you can narrow down the location? Thanks.In the last week I started getting close call hits of 170.9125 and 170.5625 both with a NAC 4F7. In the Old Bethpage area. The system ID is 4F0. Perhaps there is a site in Plainview or Melville. I hope this helps.
I get those hits while I'm mobile. I'll see what I can do.Those are both Site 127 control channels. Can you program the system with those channels in one site and verify that it's 127? Maybe see if you can narrow down the location? Thanks.
Okay no worries, don't go to any trouble. We're pretty sure it's in Plainview, there is a lot of fed stuff there already so it makes sense. Thanks again for the report!I get those hits while I'm mobile. I'll see what I can do.
168.9125c |
168.9875a |
169.6375c |
169.7625c |
170.3375a |
170.5625c |
170.675c |
170.8375c |
170.8625a |
170.9125a |
170.9125a |
170.9625a |
171.2625a |
171.4625c |
171.6125a |
171.6625a |
171.6875a |
171.6875c |
171.725a |
171.75 |
171.9875 |
172.050c |
172.6625a |
172.6625a |
172.7625a |
173.125 |
173.550c |
173.7875 |
173.725a |
173.85 |
406.6125c |
406.8125a |
407.2125a |
408.250a |
409.2125 |
[2021-12-27 20:06:25.239715] (error) P25 Parse error, s: � s0: s1: � shift: 1024 nac: 1269 type: 3
[2021-12-27 20:06:25.473266] (error) P25 Parse error, s: � s0: s1: � shift: 1024 nac: 1269 type: 3
[2021-12-27 20:06:25.554672] (error) P25 Parse error, s: � s0: s1: � shift: 1024 nac: 1269 type: 3
[2021-12-27 20:06:25.706813] (error) P25 Parse error, s: � s0: s1: � shift: 1024 nac: 1269 type: 3
[2021-12-27 20:06:25.938447] (error) P25 Parse error, s: � s0: s1: � shift: 1024 nac: 1269 type: 3
[2021-12-27 20:06:26.090938] (error) P25 Parse error, s: � s0: s1: � shift: 1024 nac: 1269 type: 3
[2021-12-27 20:06:26.243226] (info) [marsh] Decoding System ID 4F0 WACN: BEE00 NAC: 4F5
I don't know if this helps much in locating 115, but I loaded it into my trunk-recorder config on a remote machine I have in Beach Haven, NJ and looks like it connected.
I can try to get a Unitrunker capture of it when I'm there next week.
Not entirely correct. Yes, we obviously prefer the most accurate data that can be obtained, however when it comes to trunked sites the official policy is as follows:RR does not take estimates of location, at some point it will need to be pinned down by someone.
Fuzzy memory again, a search of thread reveals and refresh above recall on exactly what is permitted again. Close but again, not extract, again. Moving on, new intel on #115 with light tropo again. More data today.Not entirely correct. Yes, we obviously prefer the most accurate data that can be obtained, however when it comes to trunked sites the official policy is as follows:
Trunked system sites shall not be entered unless a site location is known at least to the county level. Sites located by means of the "neighbor site" logs of control channel monitoring programs shall be entered in the Wiki for the system unless a specific or reasonably close approximation of site location can be made.
Some activity on site 1.Been watching 117 122 and 127 all day on only a few joins on 127. Not a peep on the other two. Anyone seeing any activity at all on any of the other sites? Just curious.
./rx.py --args 'rtl' -N 'LNA:47' -S 2400000 -f 170.6000e6 -o 0 -l http:0.0.0.0:8080
Thanks, A search of this thread yields many mentions of 130. Same for 115. The location(s) are what is needed so that they can get into the DB.For those playing at home, I'm in the Philadelphia area and found site 1-130 control channel on 170.3375 MHz, 170.6250 MHz alternate. It shows sites 1-102, 1-115 and 1.128 as neighbors.
Site 1-130 and 1-128 came in about the same level from my location near PHL airport.
Watched both site 1-130 and 1-128 on PRO96COM, no affiliations or activity seen, but it was a holiday weekend.
- Chris
