Uniden SDS200 Stopped Receiving Traffic
werinshades
Chicago , IL
Ok...when I press the ZERO then the point (NO) then the number 1 and press the E (YES) it doesn't do anything...just beeps four or so times...
Are you hearing traffic? Are you seeing the F..S..D numbers I asked about?
FireLt111
Assistant Fire Chief
Ashland, Kentucky
I am NOT hearing traffic and I do not see the FSD numbers. Where would those numbers be located?
I am not on a detailed screen...should I be? I am on a default screen...showing V:16 S:2 Feb 3 16:42 etc
werinshades
Chicago , IL
Ok...the screen shows the scanner actively scanning. Periodically, it will stop on a P25 channel and you will traffic for about 2 seconds...then it continues to scan afterward....even though the traffic is continuing on the Whistler scanner.
When I press 0 (zero) it shows this: see attached...
It does nothing
This screen..
FireLt111
Ashland, Kentucky
Yes. it identifies the channel
It is sitting on:
BOYD COUNTY PUBLIC SAFETY
Boyd County Law Enforcement
Law Enforcement 2
155.670000MHz
Law Talk P25 NAC: 107h
That's it.
werinshades
Chicago , IL
It is sitting on:
Law Enforcement 2
155.670000MHz
That's it.
In the Scanner..Menu...Set Scan Selection...what do you see?
