fyerman01
Hopefully someone can help a newbie here.... I am trying to decode an EDACS Standard digital system in my local area. I am running Unitrunker connected to a BCD396XT through the serial port with a Uniden USB cable. I have the BAUD rate set to 115200 on both ends. Scanner has EDACS system programmed in and is holding on the control channel with C-CH Output set to On. Scanner also shows a full signal bar on the screen but Unitrunker is showing the health rate holding between 37-40. Any ideas what I can to do improve the health rate? Thanks in advance!!!
