Using a Boafeng UV-5R for a Broadcasting fees
Cashanova48
GMRS callsign WSAF780
I am currently planning on using a UV-5R for a Broadcastify feed and am wondering if I could use a standard headphone audio jack cable plugged into the Boafeng speaker mic and the PC's Mic input or would I use the programming cable running to the PC's USB. I am currently using Scanner cast for software. Any help would be appreciated.
nd5y
Wichita Falls, TX
You can't use a standard 3.5 mm stereo cable.
The UV-5R doesn't have a USB audio device so you can't get audio from the radio to a PC USB port. The programming cable can't do USB audio.
Here is the connector diagram.
Cashanova48
Ok, thanks. What if I ran the cable through the Boafeng hand mic which has a normal audio jack out put?
DC31
Massachusetts
Cashanova48
Almost all frequencys are in the 127 megahertz Public Service range. Everything is analog, but some channels have tones.
Cashanova48
i wanted to know what departments to see if the radio can handle it, like if it is digital.
I know I can pick the frequencys up, just didn't know what kind of equipment I needed to push the audio from the radio to the PC, but thanks.
  • Like
Reactions: wtp
DC31
Massachusetts
As noted many posts back, you need a standard audio cable ( 3.5mm) and a 3.5 female by 2.5 male adapter. That is all you need to connect the radio to the PC.
Cashanova48
I am starting a Broadcastify feed with a UV-5R and Scannercast software, and I'm wondering if there is any way to have alpha Tags (when someone talks it gives a fleet or badge number).
