Monitoring NCSHP training today on unlisted TG 52737, another group is also doing traing on SHP INV (TG 52223). Must be using loaner or training radios as they all have RIDs of 2160xxx.
I've noticed a lot of 2160xxx when I program UIDs. I've mainly on seen them on the handheld though.Monitoring NCSHP training today on unlisted TG 52737, another group is also doing traing on SHP INV (TG 52223). Must be using loaner or training radios as they all have RIDs of 2160xxx.
It looks like that 2160 is mainly used for the handheld radios I have programmed in. I'm not sure on the new troopers because we didn't get any from the last class
Discovered an unlisted NCSHP TGID of 52242 while searching on the new Gaston site. RIDs 21509xx
Only catches during the storm here'
#52255-NC S/W Calling
#NCEOC Eastern Branch
The channel lineup at some sites in the area were updated this week so you will probably need to update the control channel frequencies in your scanner. The database info has been updated.
How do i do that? Would downloading and reprogramming the scanner via PSRedit 500 do it? I'm running the Whistler 1065.
Reprogramming the scanner for those towers will do it, the new info is in RR database.
How do i do that? I'm Trying To Listen To Alamance Gibsonville PD Dispatch. I have everything in there. What Channel Do Edit?
