- Joined
- Sep 10, 2010
- Messages
- 129
I'm probably hearing them from the non-RPD agencies. There's a standardized APCO 10 code list available elsewhere on the internet, but apparently 10 codes aren't standardized across departments.
I am looking at the file. Are you referring to whether, your notes are correct?I've been logging the new Wake County P25 System on Unitrunker for over a year now, including number of hits on talkgroups since their creation. Today I reviewed the logs and found about 30 talkgroups that are active (over 5 hits since logging began) that have not been identified.
I'm including the list of those TGs with my notes in hopes that someone in the group might be able to help in figuring out who is using them (easy part, see notes) and what they are being used for (the hard part), so we can get them added to the database.
Like 46899 that just says Sheriff in your notes?Nope, I know they are correct, I'm trying to figure out what the actual usage is for those TGs. It's easy to say it is WSO but what is the usage for the TG?
Ah, Now I get it. brbYes those are the Radio IDs that are on the TG, but is it tac, jail, transport, special ops, court, traffic, patrol, or what?
This is what I have in my database:
For the Sheriff office, and they all work. I put in a test channel in that group with 46899. I haven't seen any activity on that channel.
I’m going to place all these minus the encrypted ones into a zone on my G5 and see what I hear. Thanks for the list.
I was able to get my SDS100 programmed and working. Now I am trying to get my WS1065 up and running. I used WIN500 to do an import from RR. I imported the Cary Wake P25 and the talkgroups that I wanted. I cannot hear a thing. In order to get the SDS100 to work I had to delete the Cary simulcast. I did the same thing for the WS1065. Still no cigar. What the heck am I missing????
It's very frustrating when that happens. The list may start out muted. Check to make sure that the value "Monitor = On". You may have to dig to find that option.
Everything is turned on. Nothing is locked out. The talkgroups are assigned to the Wake P25 system. The frequencies are showing up under that system. I am at a loss. Yes, it is frustrating.
I shall give it a try. Thanks for the input.When I was trying to get my Pro 106 running using that software; this was a constant thorn in my side. I ended up changing the 00 to 01 and it worked after that. The software defaulted to the 00 each time for me.
