Wake County P25 switch
JohnDistai
I'm probably hearing them from the non-RPD agencies. There's a standardized APCO 10 code list available elsewhere on the internet, but apparently 10 codes aren't standardized across departments.
zapman987
nc, recently moved to jax, FL
This is what I use. Its not perfect but gets most of them.
I've been logging the new Wake County P25 System on Unitrunker for over a year now, including number of hits on talkgroups since their creation. Today I reviewed the logs and found about 30 talkgroups that are active (over 5 hits since logging began) that have not been identified.
I'm including the list of those TGs with my notes in hopes that someone in the group might be able to help in figuring out who is using them (easy part, see notes) and what they are being used for (the hard part), so we can get them added to the database.
  • unidentified active TGs.txt
Chris0516
Pittsboro, North Carolina
I am looking at the file. Are you referring to whether, your notes are correct?
Nope, I know they are correct, I'm trying to figure out what the actual usage is for those TGs. It's easy to say it is WSO but what is the usage for the TG?
Yes those are the Radio IDs that are on the TG, but is it tac, jail, transport, special ops, court, traffic, patrol, or what? Like 47153, I'm seeing Wake Forest PD RIDs, but that TG is not in the Wake Forest TG range so why are they using it, plus the other three WF PD TGs I can't ID usage of (47251-47253)
Chris0516
This is what I have in my database:
For the Sheriff office, and they all work. I put in a test channel in that group with 46899. I haven't seen any activity on that channel.
I have all those, they are not on the list I posted, because they are identified, the channels I have on that list will not be heard often, but they are being used. I'm scanning and recording all TGs on my list but because of limited traffic they are not heard often making identification difficult.
murrayustud
KI4DCR
raleigh,nc
I’m going to place all these minus the encrypted ones into a zone on my G5 and see what I hear. Thanks for the list.
whm8019
I was able to get my SDS100 programmed and working. Now I am trying to get my WS1065 up and running. I used WIN500 to do an import from RR. I imported the Cary Wake P25 and the talkgroups that I wanted. I cannot hear a thing. In order to get the SDS100 to work I had to delete the Cary simulcast. I did the same thing for the WS1065. Still no cigar. What the heck am I missing????
JohnDistai
It's very frustrating when that happens. The list may start out muted. Check to make sure that the value "Monitor = On". You may have to dig to find that option.
whm8019
Everything is turned on. Nothing is locked out. The talkgroups are assigned to the Wake P25 system. The frequencies are showing up under that system. I am at a loss. Yes, it is frustrating.
JohnDistai
Sorry, I misquoted. I know nothing about WIN500 and the scanners outside of Uniden. I'm glad you got your SDS 100 working.
shoegazer
When I was trying to get my Pro 106 running using that software; this was a constant thorn in my side. I ended up changing the 00 to 01 and it worked after that. The software defaulted to the 00 each time for me.
whm8019
I shall give it a try. Thanks for the input.
