Well, further testing has been... Interesting! Last night I found an antenna location that yields 90% decode success. Often up to 99%, occasionally dropping to 70%. Attenuation absolutely helps both Wake P25 and VIPER reception. Even with a near-perfect decode rate, it is clear I'm still missing a lot of audio from the Wake system. At least I'm getting some now, but it's just not quite happy yet!
This new orientation is interesting, because it's not using the Yagi as one may naively expect. Because I'm 'pinned in' among all these towers, and there is an obvious rear lobe of gain, shooting for 1, 2, 3, or 5 gives me a strong signal, but plenty of distortion from behind. I did try aiming
towards tower 6, but found the best decode rate aiming 180°
away from tower 6.
This behavior, in combination with attenuation obviously improving the decoding of both systems, makes me think I'm still dealing with
far too much signal from towers I don't want to hear. Looking at signal strengths, it's basically maxed-out without attenuation on, and is still very strong with attenuation on. So my current game plan is:
- To keep the antenna exactly where it currently is (clearly I'm on to something as no other orientation has yielded such consistently-high decode rates).
- To add a variable attenuator, something like this: https://www.scannermaster.com/ATT_20_Variable_Attenuator_p/24-531021.htm
Any thoughts on this? My current theory: Now that I seem to have found a decent 'lock' on one tower, by using the Yagi's gain to partially reject other towers, I need to cut down all incoming signals, to drop those other towers near/below the noise floor. Hopefully, leaving the signal I want with enough strength for the scanner.
In other news, the old discone seems to work fairly well hooked up to my 2m/70cm HT. Looking forward to actually having a base station of sorts when I want to play around.
