2018 VHF Low Band Logs
trashman43
Kentucky DB Admin...
Kentucky
Monitored from Central Ky using a Pro 197, Win500 and a 6 meter Ringo Ranger.
Only thing of interest the last couple of weeks was
33.400 pl 150.0 unk US .mil
IcomIcR20
Are there many VHF Lo band openings during the winter? I would assume its mainly a summer thing.
I haven't spent much time on the VHF Lo bands, but I do remember a quite exceptional opening on Christmas Eve several years ago. I was getting huge signals from MD and PA for about 30 minutes from here in NC using an old Uniden scanner with a small whip from in the middle of the house. That must have been some opening!
IcomIcR20
I spent a few hours scanning through the 30/40 MHz range in our area and seeing what I could hear. There were no band opening, but these are the frequencies I found around here. I'll post them here in case it may help someone ID something they are hearing during an opening:
37.040 127.3 PL Smyth County, VA sheriff
37.320 85.4 PL Grayson County, VA sheriff
39.300 632 DCS Pulaski County, VA sheriff
39.960 192.8 PL Stokes County, NC school buses
46.450 - Rockingham County, NC fire
46.970 ? Unknown data
47.100 107.2 PL NCDOT Division 11 operations
49.480 67.0 PL Stokes County, NC Pike Electric - Mt. Airy
devicelab
Radio N.E.R.D
WA (USA)
devicelab
Radio N.E.R.D
WA (USA)
If you are looking for military stuff search 30-88 MHz in 25 kHz steps and remember that they run up to 15 kHz deviation (36 kHz bandwidth) and usually use 150 Hz tone which scanners don't have. Scanners will show the tone as 151.4 because that is the closest one which is within frequency error tolerance.
Thanks for the tip. I had a couple of old VHF low band recordings that had this 150hz tone. I used Audacity to remove the tone and now they're nice and clean. (See Post #167 for the recordings...)
devicelab
Radio N.E.R.D
WA (USA)
I was asked for a How-To to remove CTCSS tones from recordings... here's a quick tutorial:
Download Audacity Windows installer from Windows | Audacity ®
Download the installer and under optional downloads grab the LADSPA installer
Download LAME MP3 binaries here: https://lame.buanzo.org/libmp3lame-win-3.99.3.zip
Download FFMPEG binaries from here: https://lame.buanzo.org/ffmpeg-win-2.2.2.exe
Run LADSPA installer
Extract the LAME and FFMPEG binaries. Create a folder for each and place the files into them
Run the Audacity installer and launch Audacity when installing is complete
Under EDIT --> PREFERENCES and select Libraries
If Audacity hasn't detected the files then select Locate and point Audacity to the folders you created above
The versions of the binaries should be detected and you're all set.
(You can verify these also by going to HELP -> ABOUT AUDACITY -> Build Information)
Now you can open just about any audio file (regardless of extension) and work with it. Then when you're done tweaking the audio you can export it under FILE -> EXPORT -> EXPORT as MP3
To remove any CTCSS tone:
Open the audio file
Highlight the entire waveform (double-click inside the waveform boxes... the background will turn white)
From the menu, select EFFECT -> NOTCH FILTER
Simply input the CTCSS tone frequency you want to remove and say OK
Done!
spacellamaman
i got one skip in december and it had all ID info one could possibly want for a pos ID. in light of the fact that i apparently heard at least some of it wrong (town spelling seems to be completely wrong, FCC lic brings back nothing) i am going to just post the info as i heard it to possibly help someone in the future.
39.900 - PL 167.9 "...the is a test of the Newmandale Fire Pager and Alarm panel system......TNIB485" nearly exact
on 12/29/18 1820hrs
good luck and goodbye 2018, i won't miss ya
trashman43
Kentucky
Monitored from Central Ky using a Pro 197, Win500 and a 6 meter Ringo Ranger from 1-1-19 to 1-10-19
30.000 PL 150.0 Roughneck HQ in past
30.000 P25 didn't get NAC
30.300 PL 150.0 Helo
32.100 PL 150.0 band open to TX area
32.850 PL 150.0 unk US .mil
33.400 PL 150.0 Peachtree mentioned, E8 in area so possible JSTARS
34.200 PL 150.0 Range Control
60.000 PL 150.0 Helo A-A
trashman43
Kentucky
Monitored from Central Ky using a Pro 197, Win500 and a 6 meter Ringo Ranger on 1-11-19
30.050 PL 150.0 unk US .mil
30.450 PL 150.0 Ft Hood
36.900 PL 150.0 Martindale Army Heliport
33.950 PL 150.0 unk US .mil
42.500 csq Helos unk location
44.100 PL 150.0 Butts AAF
krokus
Southeastern Michigan
on 12/29/18 1820hrs
How about this as your signal source?
http://www.radioreference.com/apps/db/?fccCallsign=KNIB485
Sent using Tapatalk
wbloss
Human
Joplin MO
on 12/29/18 1820hrs
https://www.radioreference.com/apps/db/?fccCallsign=KNIB485
krokus
what kills me is i listened to that recording no less than 5 times and i still seriously mis-heard half a dozen parts of it.
KNIB485 cerainly fits the bill. makes more sense than T as well :) thanks.
Accents and digitizing can lead to odd results. :)
Sent using Tapatalk
Thezoo251
Are those various Virginia Sheriff offices still actively using low band?
I feel like they would be using the VSTARS system.
