(500) syntax error when updating SDS100
RT48
Cuyahoga County, Ohio
Here's how I would troubleshoot an FTP problem.
1. First I would verify basic connectivity by opening a command prompt and typing ftp ftp.homepatrol.com. You should get a prompt from the ftp server asking you to log in. If no prompt, TCP port 21 is blocked somewhere. Could be your computer, your router or your ISP.
2. Assuming basic connectivity, I would run the Wireshark packet capture program to analyze the dialog between my computer and the ftp server. There may well be a clue there to explain the 500 error.
I would be willing to look at a capture file posted here.
RandyKuff
Lorain, Ohio
RT48 that's a good point to use the command prompt and see what
response he gets from the server...
I'm real suspicious of his router since he says it does the same thing from two
different computers...
RandyKuff
Lorain, Ohio
icholt see if you get this response from the server to login...
