American Electric Power (AEP) P25 WACN 92715
phask
zanesville
@phask is there a way you can check Dresden or Cambridge AEP towers and see if they have Coshocton onl;ine ? Heard techs talking that it is online
Here is Dreden - shows several new neighbors.
After importing from RR - it looks like 31 31 is the only one not in RR
I'm seing a 37 37 as neigbor to Mt Perry also
Both 37 37 an 31 31 are neighbors to Zanesville
82163
n8jsw
Ohio
Ok site 27 is mt.vernon
Site 30 is brinkhaven
Site 37 is philo
So 31 is licensed to coshocton
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
I like how the RRDB fudges things up for that site -- wheeling bethelem (1F7-32.32) when it should be showing it as Dresden or whatever 1F6-32.32 is. Yes, you figured out all of the others.
Mike
wx5uif
Broken Arrow, OK
Still a bit of testing on the site here at the Leanard site.
  • AEP.txt
mtindor
FMP24 PRO USER
I'd say. I see quite a few P25 subscriber radio IDs, not just "external" patches. that's nice. The subscriber radio audio sounds much nicer than those damned patches, as we had discussed before.
There really should be more sites lit up down that way. Even though Leonard doesn't list any neighbors, don't rule out that some other site around there is online. St Clairsville (up here i the Ohio Valley) existed for the longest time, very much used, with no site neighbors listed and other p25 sites on around it. Eventually, one day it was spitting out neighbors.
Mike
n8jsw
Ohio
Just an updtate for the ones that live down by Stockport,Ohio It sounds like they have fired up Stockport and should be a peer of Macksburg and Marietta West so if anyone has access to DSD+,Unitrunker or PRO96COM please check and see if you can get some info for Stockport.
One of these should be the Control Channel
854.8375
854.9125
855.6625
856.2875
859.5625
860.8125
860.8875
Any help would be greatly appreciated
nd5y
Wichita Falls, TX
There has been some good tropo openings here the past few days and as far as I can tell everything in W OK and NW TX is still EDACS.
mtindor
FMP24 PRO USER
If you or anyone else ever takes a look at my Google Map, note the black dots in TX/OK. Those are either new site licenses or licenses with updated site locations / added frequencies. If one would go by what was seen as Ohio was being built out, The FCC license modifications and such were very suggestive of what sitess might be coming online. Sure, many sites had no changes at the FCC (other than emissions perhaps). But, I know that in Ohio they seemed to go after sites that were recently updated at the FCC first, for the most part.
So, even if there aren't sites online yet, I would expect them to be sporadically popping up pretty soon, especially in those areas of OK/TX where you see black dots.
WX5UIF has seen two sites in his area come online -- one has been online for a long long time (Leonard). Neither of those sites broadcasts neighbors currently, but nonetheless they are lit. So if you do come upon a site but it has no neighbors, people should still scan all of 854-862 mhz for any other potential online sites. in the area.
I have no way of knowing who are the usual sleuthers in OK or TX (other than WX5UIF). But my suggestion is that if anyone knows those kinds of people in OK/TX (who use things like Pro96Com / Unitrunker / DSDPlus and can check for new sites), you might want to put them on alert and give them a link to the map. Without letting people know about this thread in the MultiState forum, there are a lot of potential sleuthers out there who likely aren't even aware to be on the lookout.
Mike
b1tr41d
Raider of bits
36°44'34.30"N, 95°56'9.45"W
Mike
I'm up north of Tulsa and so far, the two sites that I can receive, Pawhuska & Bartlesville, are still EDACS.
mtindor
FMP24 PRO USER
Ok. but keep in mind they don't just put up a P25 site and immediately terminate all EDACS. The put up a P25 sites using unused frequencies on the existence license, or recently added frequencies to an existing license, or frequencies from a brand new license. In many cases, at least in Ohio, the new sites that came online to replace old ones were at completely different locations -- especially in cases where they were renting space from another tower provider and instead decided to build a new one of their own.
So, only checking existing EDACS site/channels accomplishes nothing, since the likelihood of any of those frequencies being used upon initial deployment is slim to none. Like I said, at least here in Ohio, they didn't immediate shut down EDACS -- and when they brought a P25 site online it used frequencies that weren't part of the existing EDACS sites. Frequencies from existing EDACS sites were only put into use (if they were put into use) as P25 channels after the EDACS sites were completely decommissioned. For the vast part of the buildout in Ohio, the EDACS sites ran simultaneously alongside the P25 sites. Up in my area there were P25 / EDACS combined sites for over a year and a hafl before they started shutting off the EDACS channels. I remember a site being turned up recently in central OHio where the techs specifically stated that it was running in hybrid mode with x # of P25 channels and x # of EDACS channels.
So for anyone who only looks at existing EDACS frequencies in the RRDB for a particular site, there is a good chance they would never know that a P25 site was online until the EDACS channels were all turned down and there scanners stopped picking up anything.
Keep an eye out though. If nothing has changed yet in your area, they are progressing.
Mike
b1tr41d
Raider of bits
Mike
So I took your advice and did a scan of the 800MHZ band around my area. Nothing new showed up.
I'll keep an eye out and see what if anything comes up.
mtindor
FMP24 PRO USER
Thank you. Sounds good.
Map of all AEP sites in their 11-state coverage area. I try to be diligent about keeping it up to date. black dots are sites with new / updated FCC licenses. You can disable the viewing of all states but the one you care about buy unchecking the box on the left for the other states.
Eventually I will have the full licensed list of frequencies for each site, but I don't right now. The ccallsigns are there though.
Mike
RakkFO
Central ohio
Site: 31.31 NAC=01F
Neighbor: 92715.1F6-17.17 ; Millersburg (Holmes)
Neighbor: 92715.1F6-23.23 ; Sugarcreek (Tuscarawas)
Neighbor: 92715.1F6-27.27
Neighbor: 92715.1F6-30.30
Neighbor: 92715.1F6-32.32 ; Dresden (Muskingum)
Neighbor: 92715.1F6-36.36 ; Newcomerstown (Tuscarawas)
Neighbor: 92715.1F6-40.40 ; Cambridge (Guernsey)
Neighbor: 92715.1F6-42.42 ; Zanesville (Muskingum)
Neighbor: 92715.1F6-44.44 ; Johnstown (Licking)
Neighbor: 92715.1F6-91.91 ; Utica (knox)
Channel 0-335: 855.1875 CC
Channel 0-353: 855.4125 SCC
Channel 0-369: 855.6125 SCC
2020/03/27 20:02:30 Current network: 92715.1F6 American Electric Power (P25)
2020/03/27 20:02:31 Current site: 92715.1F6-31.31
2020/03/27 20:02:36 92715.1F6-31.31 neighbor: Site 92715.1F6-23.23; CC=0-315 854.9375 Sugarcreek (Tuscarawas)
2020/03/27 20:02:36 92715.1F6-31.31 neighbor: Site 92715.1F6-27.27; CC=0-385 855.8125
2020/03/27 20:02:43 92715.1F6-31.31 neighbor: Site 92715.1F6-91.91; CC=0-387 855.8375 Utica (knox)
2020/03/27 20:02:45 92715.1F6-31.31 neighbor: Site 92715.1F6-32.32; CC=0-327 855.0875 Dresden (Muskingum)
2020/03/27 20:02:49 92715.1F6-31.31 neighbor: Site 92715.1F6-30.30; CC=0-409 856.1125
2020/03/27 20:02:50 92715.1F6-31.31 neighbor: Site 92715.1F6-36.36; CC=0-355 855.4375 Newcomerstown (Tuscarawas)
2020/03/27 20:02:55 92715.1F6-31.31 neighbor: Site 92715.1F6-40.40; CC=0-331 855.1375 Cambridge (Guernsey)
2020/03/27 20:03:00 92715.1F6-31.31 neighbor: Site 92715.1F6-17.17; CC=0-671 859.3875 Millersburg (Holmes)
2020/03/27 20:03:07 92715.1F6-31.31 neighbor: Site 92715.1F6-42.42; CC=0-393 855.9125 Zanesville (Muskingum)
2020/03/27 20:03:08 92715.1F6-31.31 neighbor: Site 92715.1F6-44.44; CC=0-313 854.9125 Johnstown (Licking)
mtindor
FMP24 PRO USER
Site: 31.31 NAC=01F
@RakkFO Thanks again!
Mike
kc8jwt
Belpre, OH
Pulled out my SDR dongle this morning to start working on this and found that my antenna was busted. I'm gonna have to work on it some before I can get some info on Belpre, Marietta, and Reedsville.
mtindor
FMP24 PRO USER
We already have all we need on Reedsville and Belpre and Marietta West. But, at some point if you do get it fixed it still would be nice to know the latest peers/site neighobrs listed on Belpre / Marietta / Reedsville.
n8jsw
Ohio
Just a heads up if anyone is looking for a site on the Old EDACS sytem and it is not there try looking in the wiki cause Obviously they are not allowed to take a site that is no longer on and take it out of the Database due to who the hell knows the reason
gtaman
TACSAT
GALAXY 19 91.0° W
Couple of talkgroups I’m working on confirming
2704 AEP IT
2010 Columbus Customer Service
2250 Columbus Switching Dispatch West
(COLW DDC)
n8jsw
Ohio
Just a fyi to all down south Ohio St.Mary's aep is online. Anyone that has the ability to copy it with DSD+,unitrunker, PRO96Com it would be great so we have the information
