American Electric Power (AEP) P25 WACN 92715
nd5y
Wichita Falls, TX
Today Mangum, OK site (1F9 33-33) is showing a new neighbor on the AEP Texas system 1F8 103-103 854.0875.
nd5y
Wichita Falls, TX
I'm copying the 1F8 103-103 site.
NAC 067
854.0875 C
854.5625 A
855.0125 A
855.3375 A
855.6875 A
Neighbors are 1F9 030-030, 1F9 033-033
Appears to be Wellington, TX
Trying to find if any more new sites came on line around here in the past few weeks.....
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
NAC 067
854.0875 C
854.5625 A
855.0125 A
855.3375 A
855.6875 A
Excellent, Thank you! I will get it added.
wa8pyr
Lead Database Admin
Ohio
OK I won't make a submission then.
Please go ahead and submit so we can keep track of data sources. A simply copy/paste of your above post should do fine.
mtindor
FMP24 PRO USER
Hopefully some other TX ones have cropped up.
Still unconfirmed via direct monitoring (but online nonetheless, not in the DB until confirmed):
1F9-8.8 Cheyenne, OK
1F9-9.9 Fort Cobb, OK
1F9-17.17 Atoka, OK
1F9-21.21 Hugo or Clayton, OK
1F9-30.30 Sayre, OK
1F9-31.31 Clinton, OK
Not noted online yet:
1F9-##.## Snyder, OK
1F9 Site Research
Google Map
Mike
nd5y
Wichita Falls, TX
I found a P25 control channel on 855.1375 with NAC 01B but it wouldn't decode and I'm not sure if it was AEP or something else.
The Snyder site should be a neighbor of several that are on line but it doesn't appear to exist. There used to be an EDACS site there that I could copy regularly.
I haven't been able to copy any of the others that show up as neighbors.
mtindor
FMP24 PRO USER
Thanks, Tom. If 855.1375 ends up being an AEP CC, it'll be site 27.27 (01b hex is 27 decimal -- and thus far they have been using the hex equivalent of the site ID for the NAC). And it would not be an OK site since we already know 1F9.27-27 and that it doesn't have 855.1375 licensed to it. So it could possibly be a TX AEP site.
Maybe Snyder has some delayed buildout due to some issues, or maybe they will simply not replace it. I don't know if some other surrounding sites provide adequate coverage for that area or not.
Mike
wa8pyr
Lead Database Admin
Ohio
Mike already added it.
Not a problem; I went ahead and submitted it, gave you credit and marked it worked. This way we have a record.
ralexander5
Mathis, Tx
Starting receiving site 1F8-057 today on 855.0625. Appears to be the new Tradewinds Tx site on WPIQ556. Will need to make a trip over that way to verify. So far no other nearby sites appear to have switched and the Corpus Christi West site seems to have been turned off.
mtindor
FMP24 PRO USER
