American Electric Power (AEP) P25 WACN 92715
KG5HHS
D/FW
I live about 10 miles NW of San Angelo, that is where I was picking up the 854.8625 from. I am now in San Angelo, no longer picking up 854.8625 but I am picking up 854.9125 (which I was not yesterday at home) and getting this now.
Network: 92715.1F8
Bandplan #0: Base=851. Offset=-45 Spacing=12.5 BW=12.5
Bandplan #8: Base=851. Offset=-45 Spacing=12.5 BW=12.5 Slots=2
Site: 32.32
Channel 8-846: 856.2875-1 CC
Site: 34.34 NAC=022
Neighbor: 92715.1F8-32.32
Neighbor: 92715.1F8-38.38
Neighbor: 92715.1F8-60.60
Neighbor: 92715.1F8-69.69
Neighbor: 92715.1F8-100.100
Neighbor: 92715.1F8-101.101
Neighbor: 92715.1F8-111.111
Channel 8-618: 854.8625-1 CC
Channel 8-682: 855.2625-1 SCC
Channel 8-926: 856.7875-1 SCC
Site: 38.38
Channel 8-934: 856.8375-1 CC
Site: 60.60 NAC=03C
Neighbor: 92715.1F8-34.34
Neighbor: 92715.1F8-112.112
Channel 8-626: 854.9125-1 CC
Channel 8-750: 855.6875-1 SCC
Channel 8-858: 856.3625-1 SCC
Site: 69.69
Channel 8-642: 855.0125-1 CC
Site: 100.100
Channel 8-1090: 857.8125-1 CC
Site: 101.101
Channel 8-542: 854.3875-1 CC
Site: 111.111
Site: 112.112
Channel 8-734: 855.5875-1 CC
Not sure if this helps, just thought I would share.
slayer816
NE Louisiana
1F9 80-80 Shreveport may have gone TDMA CC. Nothing on my radios. Unitrunker gets nothing on the first two CC's, but strong signal it cannot decode on the last one.
I need to get DSD up for Caddo Parish P25 anyway, so I'll confirm this when able.
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Looks like the Pescadito / Lobo TX site that is online is actually intended to be a replacement for the Laredo site. According to the STA for Pescadito, items were submitted by AEP to the FCC for justification of the Pescadito site.
STA for Pescadito site: ULS Application - Business/Industrial/Land Trans, 809-824/854-869 MHz, Trunked - 0009726905 - American Electric Power Service Corporation
AEP says that the Laredo tower is at risk of collapse, and that a new tower cannot be built to replace it because the county has a road-widening project that would end up putting the tower location too close to the public right-of-way and thus making reconstruction/retrofitting a non-option.
M
slayer816
NE Louisiana
92715-1F9 Site 80-80 Mooringsport, LA 9:30am 10/06/21
Peers/Control
03-03 | 08-0750
04-04 | 08-1026
05-05 | 08-0602
55-55 | 08-0778
95-95 | 08-0854
Neighbors!
I find it strange 66-66 isn't among them. It may be TDMA but shouldn't it still show up as a neighbor? I need to recheck all the new licenses and make sure I got the new frequencies because somewhere there's 5 other sites online.
mtindor
FMP24 PRO USER
Peers/Control
03-03 | 08-0750
04-04 | 08-1026
05-05 | 08-0602
55-55 | 08-0778
95-95 | 08-0854
Neighbors!
What did you monitor that site with? If you used DSDPlus, can you post the specific info for each of those peers that is in your DSDPlus.P25data file?
Mike
slayer816
NE Louisiana
Mike
Unitrunker V2. I am going to start using DSD for P25 TDMA systems soon. Just gonna take a few to get everything situated since it's not standalone like Unitrunker.
mtindor
FMP24 PRO USER
Peers/Control
03-03 | 08-0750
04-04 | 08-1026
05-05 | 08-0602
55-55 | 08-0778
95-95 | 08-0854
Neighbors!
Good luck on figuring out the peers. Most of the freqs for those peers are licensed to multiple sites close enough by (either in LA, AR or TX).
Peers of 1F9-80.80 Mooringsport - all TDMA CC
03-03 | 08-0750 855.6875
04-04 | 08-1026 857.4125
05-05 | 08-0602 854.7625
55-55 | 08-0778 855.8625
95-95 | 08-0854 856.3375
In addition, somebody submitted an update to 66 Shreveport not long ago. Those frequencies now listed for the 66.66 Shreveport site are from a brand new location of 6130 Union St, Shreveport LA on existing license WPCM970 -- although the app hasn't been approved yet by the FCC. Before that update, 66.66 Shreveport had frequencies from WPCM970 on the Power Plant / Allen Ave location.
So it looks like they got the new site location in Shreveport built out and moved 66 to that new location (db still reflects old location).
Looks like you guys down in LA are definitely going to have to use DSDPLus FL or a Bluetail Tech P25RX/RXII
DSDPlus FL is just as standalone as UT, unless you mean you to have to run two apps with DSDPlus FL versus one with UT. At any rate, if you need any assistance shoot me an email at my username @gmail
Mike
rattlerbb01
TX/LA Database Admin
Boerne, Texas
Mike
I may be back in Shreveport in November to help out a bit if our schedule stays as is.
slayer816
NE Louisiana
Mike
Disregard that email when you get it. My search bar wasnt searching...
I have an issue with SDR Sharp sending to DSD that I'll hopefully solve before this weekend, at which time I'll be back in Shreveport to get all the info I can.
slayer816
NE Louisiana
Even before this latest change; the frequencies in use by even the old EDACS system were in different locations. These locations are sometimes blocks apart and each have their own "towers". It may be accurate. Most trunking stand-alone "sites" are on one tower. But in theory wouldn't it work if certain repeaters were a few blocks down?
DeaconHarry16
Beckley WV
1F7 Site 22.22, Oceana, is reporting a new neighbor 10.10, CC-0361, 855.5125
This one is not in the wiki...any ideas for location?
Harry
mtindor
FMP24 PRO USER
nd5y
Wichita Falls, TX
There is a good band opening into E OK today. I was able to run Unitrunker on several sites.
I found a neighbor of something on 1F9 39.39 858.8125. I think it's probably Grove FCC Callsign WPCB219 (American Electric Power Service Corporation). Everything else on 858.8125 is at sites with different active CC. It's on the map but not in the db.
