HWG
E-WasteIT
Southeastern, OH
Which does address your want that it does NFM...that it won’t! Or at least it would be very low volume...
I agree. Won't be much of any volume if it can't scan it! That's why I went to the chart and added it in here for informational sake. Forums are good with accurate information; not so much with the opposite.
CanesFan95
Was Homeboys-Scanna
Banned
FL
Ham radios usually have much better receive than scanners.
CanesFan95
Was Homeboys-Scanna
Banned
FL
You'd be surprised how deaf a lot of scanners are when you put a ham dual-bander on the same antenna.
jonwienke
More Info Coming Soon!
VA
Any scanner will be deaf after doing that, if you bump the transmitter key even momentarily. You'll instantly fry the front end.
N8YX
Weighing in:
I have a pair of BCT-15Xs in addition to a lot of other analog and digital-capable stuff. RF-wise, the 15X works well - but it isn't my first choice for a weak-signal analog analysis unit. That nod would go to one of several R-7000s in the lineup. My main gripe is that only the BCT-15 and not the "X" model are supported under TrunkStar Elite - which is a package I'm considering buying. My 996XTs (as well as the 996P2) are supported, however. Go figure.
One of my 15Xs has a discriminator tap and I'm going to mod the other the next time I have that side of the monitoring post powered off. Thoughts are to use them with FreeScan to search air-band frequencies, or run the pair of them with trunking decode and DSDecode, PDW and similar utilities. Would I buy them again if I had to? Yes.
Another pair of analog scanners I own are Pro-2006. OS-456 Lite boards were obtained many years ago and I just got around to getting the second of two 2006s to receive these. They compare favorably to the OptoCom (two in use here) and the Pro-2035 (one currently), all of which compare favorably to the -15X. I still go back to the Icoms for digging the very weak stuff out of the noise, but the rest of the GRE and later Uniden gear definitely merit their spots on the shelves.
Something to consider about amateur rigs used for scanning: In my experience, many of their BPF responses tend to favor the amateur bands +/- a couple megahertz for MARS usage. A couple I own which receive from 136-174 (for example) go practically deaf at 160MHz. The type of front end has a lot to do with this - if the rig in question employs a helical resonator setup, it's going to have a very narrow response. Wider front ends invite intermod, though.
...Fred...
CanesFan95
Was Homeboys-Scanna
Banned
FL
I think you missed the point. I didn't say to transmit. Don't be silly.
jonwienke
VA
I'm not. It's easy to bump the button accidentally, and it only takes once to let the magic smoke out.
Also, many ham radios have very narrow front ends, and go pretty much deaf once you get a few MHz away from the ham bands. So that's a consideration, in addition to their glacial scan rate and other issues.
iMONITOR
Silent Key
S.E. Michigan
Weighing in:
...Fred...
TrunkStar Elite??? No disrespect, but that's so 1980's.
Seriously Fred, before you buy that check out ProScan! You can buy it for less and it does so much more! Plus it will work with all your Uniden scanners. You have to buy a separate version of TrunkStar Elite for each scanner.
N8YX
Just had a look at ProScan. Thanks for the heads-up! Going to download their eval version and try it over the weekend; should it do what I want I can see a 4-license purchase real soon.
iMONITOR
Silent Key
S.E. Michigan
Per the license you can run numerous sessions of ProScan on one computer (in different folders), and "I think" you can install it on two of your own computers! Support from Bob is super!
CanesFan95
Was Homeboys-Scanna
Banned
FL
So then just remove the mic or whatever. My Icom ID-880H is fast, but not as fast as a scanner and is harder to use. But the receive? Forget it. On the same antenna, it picks up stuff the scanners don't even know about.
vagrant
ker-muhj-uhn
California
I use my ham radios daily to scan amateur and non amateur freqs and they work well. They are not deaf, even when using antennas tuned for the amateur bands. Perhaps the radio or antenna you tested had an issue, or was not made for a wide RX coverage. Which models did you test? Were any of them made in the last 20 years?
N8YX
Currently have it set up running 1ea 996 and 15X. Yes, you can install it on two of your own computers (per license). I'm going to buy two licenses as I have a total of four I use for various monitoring-control functions.
I know the 996 and successors output control-channel data natively. Is there a way to make a -15X do this and have ProScan recognize it?
N7OLQ
Scanning since '77
Utah
On the 780XLT, if you set the step to 7.5KHz first, you can program 155.7525 and it will store it that way.
chief21
Western NC (Summer); Tampa Bay FL (Winter)
I can confirm that the 780 will accept a step setting different from the default if the step setting is changed before entering the frequency. Step choices are 5 / 7.5 / 10 / 12.5 / 25 / 50 / and 100 kHz.
iMONITOR
Silent Key
S.E. Michigan
Anyone know what happens when you import data into the BC780-XLT from the R.R. database using ProScan?
HWG
E-WasteIT
Southeastern, OH
@mass-man Have you tried this?
