Seriously - How much of Columbus rail traffic is NXDN? From what I understand, none. I thought they were only using it in selected areas with no interconnections or yard work.
Most rail traffic in my area is NFM analog.
That's a good question? I had thought none as well, and yet the Digital Frequency Search site says there is a whole bunch of it on NXDN. I suppose just because it says so doesn't make it true, but from what I have heard that site is kept up to date. Or at least it was? Maybe that has changed...?
Then perhaps Uniden is of the same mind and really has no plan to release a NXDN solution...
Not necessarily. NXDN is used by entities other than railroads. And I make no representation that traffic in my area is representative of traffic nationwide.
Just because someone has a license that allows NXDN doesn't mean they are using NXDN. There's a bunch of NXDN rail licenses in my area, but I still mostly hear analog FM.
Of course we know that the latest models of Whistler scanners can handle conventional NXDN, but it seems that making a scanner that can properly track trunked NXDN might be be giving scanner developers and engineers a bit of difficulty. Unlike with Motorola and other systems that use a standardized channel map for trunking, NXDN allows trunked system operators the ability to develop their own channel map. And therein lies the rub. In order to track those systems, you'd need to know exactly which frequency has been assigned which channel number. There is a large NXDN trunked system operator in the midwest that has a channel map consisting of over 1000(!) channels. There is no rhyme or reason to the layout of these channels, and they are not in frequency order. On top of this, selectivity might also be an issue due to how narrow these signals are. The system operator mentioned above uses many 3.125 kHz splits. And to add to the mix, they often use frequencies that are 3.125 kHz off of the licensed frequency. If you're not looking at the signal on a service monitor or with a dongle and a program like SDR#, you may not realize this.
Bottom line is that it isn't as simple as one might think for even the major players to come up with a scanner that will track trunked NXDN.
We have several things that are very close to fruition and something on the further horizon that I think you'll go ape over. But, I should be back by then and really shouldn't tease you like this.
Or, one could even be a free firmware release.
https://forums.radioreference.com/uniden-tech-support/359561-bcd325p2-bcd996p2-update-1-07-09-a.html
That probably covers the "things that are very close to fruition". It's the "further horizon" ... "go ape over" I'm talking about.
Given your track record on predictions, I'm now very sure that there is no new hardware on the horizon.
I have to be right at some point, eh?
