APX P25 radio aliases
N0BDW
Livingston Co., NY
Howdy.
Is it possible to display P25 RIDs as an alias on the APX series radios? For example instead of RID "612504" to display I'd like to have it say "LFD 2504." I know our dispatch consoles already do this.
Also: is it possible for the system to transmit these aliases? So that if an alias needs to be changed it doesn't need to be updated in each piece of subscriber equipment?
Thanks.
Project25_MASTR
Millennial Graying OBT Guy
Texas
I don't remember if enhanced ID has to be in the flash for the APX line but yes, ID's can be aliased.
Can the radios send the alias over the air...not in any current Astro25 releases.
Here's a copy/paste from one of my posts. This should help:
"1) As N1GTL explained, you must first go to Radio Ergonomics > Display, and scroll down to “ID Display”. Use the dropdown next to the “PTT ID DISPLAY”, and select “Dispatch and Scan”.
2) Going back to the “Codeplug Configuration” tree, scroll down to “Conventional Configuration”, and select the “Conventional System” menu.
3) Right-click on the “Conventional System” menu, and select “Add”.
4) Now select the system that was just created, and left-click on it to open it.
5) Under “Conventional System Name”, erase the generic name and call it whatever you want. For this exercise, I’ve called mine “FIRE”.
6) Directly beneath that, locate the “System Type”. Mine is defaulted to “Astro”.
7) Use the dropdown to select “MDC”.
8) Now, go back to the “Codeplug Configuration” tree, and select “Conventional Personality”.
9) Assuming you already have created personalities, click on a personality that you want to assign the MDC system to. In this exercise, I’ve created “SGFD”. If you haven’t yet created a personality, go ahead and create one that will have this MDC system assigned to it.
10) Once you’ve built out the personality (an exercise I won’t go into here), continue scrolling down beyond the frequency inputs and options, and find the “Signaling” sub-menu.
11) Within the “Non-Astro” menu area, locate the “Signaling Type” dropdown menu, and select “MDC”.
12) Directly beneath that, locate the “System Number”. Change that to the system you created in step 5.
13) Going back to the “Codeplug Configuration” tree, scroll down to “Call List Configuration”, and click on “Unified Call List”.
14) Across the top of the screen are symbols. Click the “+” symbol to add a new “Contact Name”. This will create a generic contact; something along the lines of “Contact 00126”, in my case.
15) Highlight the generic contact name, and call it whatever you want. In my case, I’m going to call this contact “Battalion 1”.
16) After you’ve named your contact, click the little arrow to the left of the contact, so that the contact is highlighted blue.
17) Looking back up at your symbols across the top of the screen (where the “+” symbol is), select the blue folder (to the right of the trashcan). This opens additional options.
18) You now have several ID options, as well as the option to rename your contact if you so wish. Technically, you could have skipped step 4, and simply renamed the contact here. I learned that it’s easier to name it first, so that you are ensured that you have the correct contact open in this screen. Keeping the generic name, and renaming it from here, caused me confusion as I entered hundreds of these ID’s.
19) The option you want is “MDC Conventional ID”.
20) Along the “MDC” ribbon, click the “+” symbol.
21) Select the “System Name” from the dropdown menu. (Created in step 5, and assigned in step 12).
22) Under “Primary ID”, enter the MDC ID number
23) At this point, you are done. Your radio will read the ID and, if the ID has been created as per these steps, your screen will display the alias as opposed to the number.
The steps here are the same for Astro ID’s. The differences are:
1) When you build your system in steps 5, 6, and 7, you’ll select “Astro” as the signaling type.
2) When you build your conventional personality in steps 10, 11, and 12, you’ll instead use the “Astro” signaling sub-menu, and change the “Astro System” to whatever you created in steps 5, 6, and 7 (reference 1 above).
3) Then, instead of creating a “MDC” ID in step 19, you’ll create an “Astro Conventional ID” by selecting the Astro system you just created, and changing the “Individual ID” to whatever the correct number is.
Outerdog
T¹ ÆS Ø
The off-topic diatribe about MDC posted above is utterly useless. Aliasing in APX CPS is different than XTS/L aliasing anyway.
For APX CPS, on the main codeplug configuration tree, look at Call List Configuration. The idea is to create Contacts within a Unified Call List. You can assign different IDs to different system types. In your example, you would want to create an entry under Astro 25 Trunking ID associated with the trunking system in question.
It is possible for the system to OTA alias information to the fleet, but I don't work at that level and am unfamiliar with the configuration. Note that any changes made to aliases in CPS will overwrite any OTA alias information the radio may have previously received.
The APX CPS has additional information.
N0BDW
Livingston Co., NY
Thank you Outerdog. I'm going to pursue the OTA option with the county and see what they have to say about it. If they aren't open to the idea I'll look at doing it through CPS.
Fighting with phonies is useless. Never mind. Thanks for the "CPS has additional help". That's very helpful!
N0BDW
Livingston Co., NY
Sounds like the county would like to do the OTA aliasing, but they need to install a service pack or somesuch. Hopefully that works out as it would save frequently having to reprogram radios (we don't have OTA programming).
ResQguy
Meh
The subscribers and the system both need to group services option enabled to do OTA aliasing. The system needs to be at release 7.17 or later to support this as well.
