Armada Software + VP8000
otobmark
NC
You probably set up the template wrong. When you hit Add a template you get a box for template name and another labeled Band with a drop-down of 17 combinations of bands and frequencies. You want the last: 7/800 VHF UHF.
AM909
Radio/computer geek
SoCal
My VP8000 bottoms out at 450MHz. Any ideas why? VHF works great, wideband, etc, all golden. It's got all features unlocked. Perhaps it's just a T-Band model?
When you create the system, you choose the band(s). The spaces in the names make that confusing. "UHF" is 380-520, "UHF 380" is 380-477.425, and "UHF High" is 450-520. You chose "7/800 VHF UHF High" when you probably want "7/800 VHF UHF".
WTF is 477.425? :)
otobmark
NC
If you don’t want to start over you can duplicate the template you have and a menu will pop up to select Band for duplicate. Select correct band for duplicate and you should be good to go.
tweiss3
Is it time for Coffee?
Ohio
So I just put in an order for a VP8000, and re-reading post 8 is causing me confusion.
Another thing to mention regarding wideband is that Armada allows wideband receive on any frequency as long as the non-exempt transmit frequency is disabled.
420-450MHz
I guess, what does the Wideband Disable prevent? Does it allow wideband on 420-450 (ham)? Or does the above comment indicate two separate facts?
AF1UD
Wideband disabled means that you can't set most frequencies to wideband. Wideband is allowed wherever it is legal... ham, marine, and a few others.
wd8chl
...on the VP8000. On 5000/6000/7000 series, it doesn't allow WB on UHF below 470 I think. The 8000 is smarter.
AF1UD
Correct. To my understanding the 5/6/7K are all built off the NX-5K. This is why they look and act similar. The 8k was completely redesigned.
tweiss3
Ohio
Great, that's what I thought, but wanted to double check.
I'm also reading the manual, and I may have found an issue with radio wide scan. Per the manual:
I should be able to put 255 channels in the RWS list, but under Global ->Lists->Radio Wide Scan, it only allows 64 channels. Misprint, or an issue with 1.42.12? I should have my subscription soon and have the current Armada.
otobmark
NC
I have latest cps/firmware and a 4096 channel radio and I see same 64 limit you do. I wonder what the scan rate is in channels per second? Would analog channels decode faster than digital? When I scan lots of channels on a scanner I miss lots of traffic partially and completely. Trunking scan on 1 system is quick because radio stays on control channel just looking for digital signature. Multi system and multi channel much bigger issue.
