BCD436HP / BCD536HP Repair Campaign
bob550
Albany County, NY
But If I remember it gives you the option to hit the E to set time and date...
Hit the . to bypass instantly or just wait 10 seconds for it to go around the setting...
And all that does is to make an already time consuming start-up even longer. :(
RandyKuff
Lorain, Ohio
Yep... Would have been nice to just have a menu setting to just turn it off completely
jonwienke
More Info Coming Soon!
VA
It was only intended as a workaround to avoid hanging the scanner until it could be sent in and fixed.
RandyKuff
Lorain, Ohio
Yes... I know it was a patch till you send it in...
But there are people who don't use the recording function and could care less about the clock...
Would of been nice to just be able shut the clock off in a menu setting if you so desire...
jonwienke
VA
Most of the units with bad clocks had display issues as well.
jonwienke
VA
The backlight fades out over time. Some units dimmed a lot more than others.
bob550
Albany County, NY
Since the battery is certainly a problem, I'll send it in for repair. If Uniden feels the display is too dim, they're welcome to fix that too.
bkramm
Benton County, IA
Just sent my 536 into repair for both the clock issue and the dim display.
From date sent until return was just under two weeks with both items repaired.
RandyKuff
Lorain, Ohio
I bought mine July 27th 2014....
Use the link in the first post...
They pay shipping both ways... Can't argue with that...
madrabbitt
NM
I guess i'm going to send mine in, since work is finally slowing down (assuming something outside california doesnt catch fire)
Been dealing with the clock issue for about a year, but the display dimming is what finally bugged me enough to decide to do it.
jbella
GDM/OOB
Anyone else have issues with your email 'not being found' by Uniden.
Has there been a recent change where you'd have to resubscribe? Yes, my email was typed in correct (5 times), yes, I tried any alternate emails I have.
seesharp15
Ummm... not sure, but I just had the same issue, and realized that it was now case-sensitive.... so maybe try making sure your email/username is EXACTLY how you registered it.
advcomp2019
I have a BCD436HP that I registered years ago for repair, but I never shipped it in due to personal reasons. Do I have to re-register it, or can I use the old shipping label from years ago or how do I go about getting this RTC fixed since it was registered already?
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
I would reach out to @UnidenSupport for advice.
