BCD436HP / BCD536HP Repair Campaign
mrkelso
NNJ
Are many people still waiting to be called in for repair?
Soundman
N.C
I have been waiting .Thy said thy need to get parts for BCD436HP ..Then send use a email.
garys
Central Texas
Ditto. I'll send my 536 and 436 back at the same time once I receive notice that the 436 parts are in.
mjs438
Philadelphia, PA
UPMAN
I haven't experienced any issues with my scanner. Does Uniden know what serial numbers are affected. My serial number for my scanner is 375Z48004556?
If my scanner is affected I would like to know so I can get the fix also.
Voyager
I don't think they know of specific S/Ns that are affected. But, the campaign might give them some insight into that.
You will know your unit is affected if the RTC loses time immediately or the display is too dim to read on HIGH.
Isaac-1
Mine started only keeping time for 2-3 days, then a few days later it was down to 1 day, then a few mores days later and it was down only keep time for a few minutes.
divison200
Cambridge, Ma.
Serial number range for x36 series
To help out mjs438, Serial numbers below 48002600 have been affected for this adjustment
fxdscon
¯\_(ツ)_/¯
There have been no serial number ranges published for this repair campaign.
The serial number you are referring to might apply to the headphone repairs campaign from last year.
Voyager
I think that's what the 2600 is - the headphone issue cutoff.
kc2kth
Toms River NJ
Still waiting here for my invite to send in my 436, I only submitted the request on around 12 October though so I was a bit late.
JoeyC
Senior Member
San Diego, CA
Well since it has already been stated that the parts for the 436 weren't due in until the first to middle part of December and today is only the 1st. I don't think you are late.
mjs438
Philadelphia, PA
I sent my scanner in for repair on 11/30 since I could not determine if mine had an issue other than the brightness of the display. Which I did'nt realize it was an issue until reading about it, and I noticed it could be brighter. Counting the days missing my scanner.
troymail
Silent Key
Hmmmm.. did you send it in as part of the repair campaign or separate from that? Given your comment, if sent in as part of the repair campaign, I'm curious to learn what happens.....
mjs438
Philadelphia, PA
Troymail,
Sent as part of the repair campaign since no one could tell me if me scanner is impacted. Figured Uniden would know so I submitted request with the serial number they sent me a notice to ship scanner to them. So that tells me they know they scanner has an issue At least they will check it out and repair if necessary Paid to much money for scanner not to have it checked out and fixed if necessary.
Voyager
It's easy to test. Is the display unreadable on high brightness? If you turn the scanner off and on again, does it tell you the clock settings were lost? If you have either of these, it is affected.
mjs438
Philadelphia, PA
I had set the brightness to high and it seemed to get brighter and it was readable but it still looked dim. I had nothing else to compare it to since I only had the one scanner. Clock issue I do not have.
marksmith
Anne Arundel County, MD
Am I confused, or what?
My understanding is you can send them in if you have the clock issue. The screen dim issue is being treated as a byproduct of the clock issue.
If we don't have the clock issue but have a dim screen, are we now supposed to send in? I have been waiting for the go on screen only.
WS1095/536/436/996P2/HP1e/HP2e/996XT/325P2/396XT/PRO668/PSR800/PRO652
