BCDx36HP Update 1.16.00
vocoder
Indiana
Both nxdn 4800 & 9600 are working better with the new firmware 1.16
cap+ requires a crystal clear and strong signal, working better with the new firmware
W4KRR
Coconut Creek
I found that is it working but not 100%. Sometimes I see a RID instead of the Alias, however watching two radios at the same time one will show RID and one will show Alias. So there must be a timing issue related to when the scanner "sees" the data from the CC/radio. I would say about 90-95% of the time both showed the proper Alias. I sent a debug file to Uniden.
I am seeing the same thing. However, a friend of mine says he never sees a NXDN alias on his 436 with the 1.16 FW. We both monitor the same system. I don't know what his issue could be.
bearcat
If your friend has the RID#s programmed in the system, then I believe it will show the programmed RID info and not the Alias, also are the RIDs turn on?
garys
Texas
This may be it, because I'm intermittently seeing the Alias, but always seeing the UID. At first I thought it might be the length of the Alias, but I'm not totally sure.
Maybe that will be resolved with a future update, but overall I'm very happy with this revision.
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
On my DSD+ setup, OTA aliases take about 3/4 to 1 second after the transmission begins before they show up, and sometimes they show up in pieces, i.e. if SMITH is the ID, I might see -MI-H, then a second later -MITH, then SMITH, as the data is delivered.
My setup is about 30 miles from the tower, so it's possible that the signal needs to be stronger in order for aliases to be reliably delivered. I wouldn't be surprised if the scanner has the same issue.
wx5uif
Broken Arrow, OK
Yeah, I've seen DSD do that as well. Also, DSD saves the alias in the DSDPlus.Radios file, so when the UID is present again, it auto shows the alias. This is some of the reasons DSD seems to show alias better.
bearcat
It is great having the Alias info. Building a RID file with Alpha tags based on the Alias info will still be great even if the issue cannot be resolved.
W4KRR
Coconut Creek
Are you sure there's an option to turn RID's on and off?
jasonhouk
Marion, Ohio
Yes, under Display Options
Sent from my Moto G (4) using Tapatalk
jonwienke
More Info Coming Soon!
VA
Another log file:
https://1drv.ms/u/s!ApJIS-l4xqPtgvEtfqduv4ZYVJFyDg
The only traffic in this log is from the jail system (color code 8). The scanner picked up some traffic, but usually only when there were several transmissions in a row. Typically the first transmission or two was missed, and the third or fourth in the conversation were the first picked up. But once it locked on the conversation, the scanner would usually play the rest of the transmissions.
I was only monitoring the school and jail systems (4 frequencies total), so in the absence of traffic, each frequency was being checked several times per second. So the scanner should have had no trouble at all consistently catching the first transmission in a conversation. But it only did maybe 10-20% of the time.
werinshades
Chicago , IL
This would be a handy feature in the future if possible. The option to disable it and just see the UID's might benefit us at times too. Firmware update went through without a hitch for 2-536's and 1-436. Been using the 436 frequent enough to concur that the squelch gremlin has been eradicated. All other systems have been tested and can report no degradation occurred as a result of the firmware upgrade for me.
cironside
Firmware Update 1.16.00
can some send me the new update please and thank you as I do not use the Sentinel software or provide me with a link where I may dload this please and than you any help would be great full
Jay911
You are required to use Sentinel to update firmware on the x36 line of scanners, and to update the database.
Why do you not want to use it?
cironside
Because I always gotten it from the yahoo groups but for some reason it has not been posted up there as well I have tried to post a couple of times and my post are not getting posted so not sure whats going on
nosoup4u
High Bridge, NJ
Listening to the 536 remotely I am getting a weird digital hum after a digital transmission which seems to last for a good 20 seconds (on and off). I thought it was proscan, but I connected directly with VLC and I still get it. I don't hear it when I am listening normally through the speaker. I have 2 536's and both are doing it on this firmware.
I attached a quick recording of what it sounds like (at the 8 second mark). I will hear it often after the transmission ends and while the radio is scanning.
  • 04-25-18 08-57-17 - NJICS 700 System - South Patrol.zip
ProScan
Software Provider
Ontario, Calif.
I take it you are using the Wi-Fi. Sound should be total quiet when no transmission is present. My guess is the computer speakers enhancements are on. Turn off the enhancements if on.
If still not resolved, perhaps revert to firmware 1.15.00 just to be sure.
{edit} Does it happen only with digital. Is that P25, DMR, or NXDN only? Does it do it with a conventional channel. Try weather and go into the menu to stop the weather receiving and see if it still happens.
nosoup4u
High Bridge, NJ
{edit} Does it happen only with digital. Is that P25, DMR, or NXDN only. Does it do it with a conventional channel. Try weather and go into the menu to stop the weather receiving and see if it still happens.
This started after the firmware update, it doesn't it on 1.14. I didn't make any other changes except for the firmware update.
ProScan
Software Provider
Ontario, Calif.
I would double check and triple check. I hear that all the time with regards to no other changes made then later I hear, that an option was inadvertently turned on I forgot about.
