I remember it happening on my 436hp. I cleared my recordings and it quit doing it.
Because I always gotten it from the yahoo groups but for some reason it has not been posted up there as well I have tried to post a couple of times and my post are not getting posted so not sure whats going on
I just ran about a 1/2 hour test my Android tablet and I am not experiencing any issues. I tried an Ipad also and it was fine.I am getting it on the android app also
Went to test the 1.16 firmware on the NXDN48 system that uses the Direct Frequency Assignment (DFA) and the new Firmware does not allow reception of this system.
I had programmed all the frequencies in with LCN of 0 to use the LCN finder. I turned on the LCN Finder through the menu and saw 0/8 LCN found. Almost immediately it said ALL LCNs Found and prompted saving. I saved it and it immediately went to 1/8 LCNs found and stayed that way for 20 minutes. While this was going on, my DSDPlus setup was following traffic so there should have been more LCNs found.
I went into the system via the menu and found that the LCN that had been assigned to the Control Channel was 20012.
I deleted that and reran the LCN Finder and the results were the same.
I scanned for a while with this odd LCN that the scanner found on the control channel and only got a quick popup for each transmission. A couple were as long as a second and I was able to see some TGIDs but they did not come close to matching the DSDPlus display. They were however, matching the radio IDs of whoever was talking but showing it as a TG.
I did not catch a Control Channel swap so I can't say if a different CC would show another strange LCN.
chris
I Don't get it why one can not dload the 1.16.00 directly other this SentinelFor NXDN DFA, just set the control channel frequency and run LCN finder. No need to put in the voice channels. If it does not work well, please capture logs from the control channel and one voice channel in conventional mode.
Listening to the 536 remotely I am getting a weird digital hum after a digital transmission which seems to last for a good 20 seconds (on and off). I thought it was proscan, but I connected directly with VLC and I still get it. I don't hear it when I am listening normally through the speaker. I have 2 536's and both are doing it on this firmware.
I attached a quick recording of what it sounds like (at the 8 second mark). I will hear it often after the transmission ends and while the radio is scanning.
OK double checked my settings and nothing changed. This behavior is only happens using ProScan as far as I can tell.http://cloud.tapatalk.com/s/5ae0c60437e60/20180425_141310.mp4
If you've never installed Sentinel, and used it to update your scanner, your database in the scanner is seriously out of date. Probably several years, as the initial database load harks back to when the scanner was first released for sale. That's why your first move, on any of the database scanners (Uniden x36HP series, Home Patrol-1 or -2, and the Whistler scanners such as WS1088, WS1098, and the TRX series) should be to download and install the software provided by Uniden or Whistler, then download the most recent database version.A number of systems, in both Canada, as well as in the U.S. have changed over time.Because I always gotten it from the yahoo groups but for some reason it has not been posted up there as well I have tried to post a couple of times and my post are not getting posted so not sure whats going on
