OK, thanks for the info, guess my problem is not the band plan. I'll check further.
Hi thom,OK, thanks for the info, guess my problem is not the band plan. I'll check further.
Hi thom,
I have a BCD996P2 scanner which I have been unable to get to work on CSERN but worked on CSP 800MHz for 10 years flawlessly
Today they were doing Corrections Vehicles.thought they were done!
What scanner are you trying to program?
no program ct state police file code like file 36 37
yesYou're not asking your question very clearly. What are you looking for.
File codes for CT State Police?
I am looking the ct state police file code I have some file code from RadioReference.
I have some from 01 to24 there is more can some help me
Thank you
Eddie
Hopefully not. That is scary. I can only really hear the state PD from here. If they're not listenable then that's going to be a major blow ...Same here. E C D F K all 100% signal off multiple control channels. The new system off the E site, nothing. Nobody seems to have an answer yet. Just wait and see until the full switchover happens. I'll give you an example though. I travel to Jersey once in a while. The state has two systems in use currently. The old 800 analog trunk which works 100% for me anywhere in the state I've been. Then there's the newer 700 P25 system which is a huge pain to try to monitor. Hopefully that's not how CT ends up being.
